- Thank you received: 1
jet needle - BS34 Mikuni
- squints
30 Sep 2009 19:49 #324835
by squints
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
jet needle - BS34 Mikuni was created by squints
could someone tell me if the jet needles from this model carb.(BS34) come with adjustable clip positions. My manual says US versions came with one fixed position.:ohmy: That really cant be true!
I was hoping someone could tell me, before I go ripping things apart with only a few more warm days left in the northeast!:laugh:
and if this is a fixed needle, where can I look for different sizes or adjustable type needles that would fit.
Upstate NY
- Buda
30 Sep 2009 20:11 #324843
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic jet needle - BS34 Mikuni
If they are US model carbs they have only one slot.
You can use shims to do the same thing.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- dadams7161
- live to Ride Lifes Better on the Road in the wind
01 Oct 2009 07:57 #324889
by dadams7161
1982 KZ750-M1 CSR Twin
3rd Owner of this Jewel
Before and After Photos
Replied by dadams7161 on topic jet needle - BS34 Mikuni
Yes the BS34 does only have one position on the jet needles these are the carbs I have also
- roy-b-boy-b
- Thank you received: 103
01 Oct 2009 08:15 #324891
by roy-b-boy-b
Replied by roy-b-boy-b on topic jet needle - BS34 Mikuni
You can order the shims from jeff @Z1 enterprises.
- squints
03 Oct 2009 09:12 - 03 Oct 2009 09:13 #325234
by squints
Upstate NY
Replied by squints on topic jet needle - BS34 Mikuni
Ok, now that I've re-read my manual, and read these posts, this makes sense. I want to richen the mix, raising the needle is what I wanted to do....
is two shims the limit?
thanks all.
thanks all.
Upstate NY
Last edit: 03 Oct 2009 09:13 by squints.
