smoke,hesitation,and popping.
- roccbottom
- 1984 gpz1100, 1995 kz1000p
27 Sep 2009 17:03 #324342
by roccbottom
smoke,hesitation,and popping. was created by roccbottom
guru's i need your help. i have a 1984 gpz 1100,stock engine.4 into 1 yoshimura exhaust.vm 29 carbs with pods.it starts right up,but when i hit the throttle i get hesitation, and brown smoke.when i shut it down i pulled off the pods and # 2 carb was smoking. as usual all advice is appreciated.
- keith1
- Thank you received: 2
27 Sep 2009 17:20 #324345
by keith1
Replied by keith1 on topic smoke,hesitation,and popping.
brown smoke is from overheating....can ya give a little more info as far as history?....i m guessing the bike was converted over from injection?....not gpz expert...
- PLUMMEN
- Thank you received: 104
27 Sep 2009 17:52 #324365
by PLUMMEN
Replied by PLUMMEN on topic smoke,hesitation,and popping.
84 gpz1100!!!!!!!!!!!!!!!!!!!!!!!!!!! i know we just met but,i think i love you! is it silver by any chance?
:laugh:
- roccbottom
27 Sep 2009 18:12 #324377
by roccbottom
Replied by roccbottom on topic smoke,hesitation,and popping.
the fuel injection was removed,and the mikuni carbs were on it when it was given to me.it has 125 mains i cant remove the others, to check. i had ridden it about 3 months ago, and the only problem was it was not charging.
- keith1
27 Sep 2009 18:26 #324381
by keith1
roccbottom wrote:
you need to assess what you have....oil at proper level,gas good, spark good, compression good......has bike been sitting for years before you fired it up?...there are a lot of variables......
- roccbottom
02 Nov 2009 16:21 #331171
by roccbottom
Well guys its been a minute.but I finally got around to solving 90% of the problem IMO, I finally did the wg ignition upgrade.MAN she woke up!!! i now have snap in the throttle,smooth throttle response,and even idle up to red line,when i back off the throttle,last issue the puff uf dark smoke,when i rev it high and let go, So to those that chimed with the informative suggestions.I thank you, keep the knowledge flowing....peace and chicken grease RB.
