Pitcock help
- Eldiablo
- 1978 kz650 with 81 750 motor
26 Sep 2009 19:56 #324169
by Eldiablo
1978 kz650 with 81kz750 motor, dyna coils/pickup, 4/1 header, d&d pipe, pods, gsxr brake controls, airtech clipons, r1 taillight, and cafed out
Pitcock help was created by Eldiablo
Is there suposed to be a tube coming out of the pitcock into the tank for the on position. Mine has the 2 holes going into the tank but I can't figure out how it's got a reserve of gas
- Thank you received: 2829
26 Sep 2009 19:59 #324170
by 650ed
Replied by 650ed on topic Pitcock help
What model Triumph?
- Eldiablo
26 Sep 2009 20:30 #324175
by Eldiablo
Replied by Eldiablo on topic Pitcock help
Sorry not the triump.
78 650 tank
78 650 tank
- timebomb33
- Thank you received: 10
26 Sep 2009 21:09 #324185
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Pitcock help
the petcock has two feed tubes up in the tank one is shorter than the other that one is your reserve.
- Eldiablo
26 Sep 2009 21:19 - 26 Sep 2009 21:21 #324193
by Eldiablo
That would explain why when I ran out of gas the other day the reserve did nothing to help me not walk my bike 300 yards to the gas station.
I am assuming that the larger hole in the center is the one the tube for the main fuel pick up
Last edit: 26 Sep 2009 21:21 by Eldiablo.
- timebomb33
26 Sep 2009 21:53 #324201
by timebomb33
yes i think it is mind you it has been awhile since i've had one of those apart
- Bluemeanie
- Thank you received: 14
27 Sep 2009 05:41 - 27 Sep 2009 05:46 #324218
by Bluemeanie
Replied by Bluemeanie on topic Pitcock help
Yes, there is one tube that sticks up for the main feed. When fual level goes past that you start sputtering at 70 mph. Turning petcock to reserve opens uo lower hole and allows you to continue on for approx .7 gallons. (The tube slides up and down in the screen), pull tube down and then push tube into larger hole (only fits in one hole) then push in screen assembly until flush with petcock. Are you missing this piece?
Last edit: 27 Sep 2009 05:46 by Bluemeanie.
- wes_scooter
27 Sep 2009 09:05 #324255
by wes_scooter
76' kz900
70' yamaha R5
2006 wr450f
Replied by wes_scooter on topic Pitcock help
sounds like yours is missing the stand pipes. you might look at z1 for a new petcock or just really watch your mileage.
76' kz900
70' yamaha R5
2006 wr450f
- Thank you received: 2098
27 Sep 2009 09:31 - 27 Sep 2009 09:35 #324262
by Patton
Replied by Patton on topic Pitcock help
Last edit: 27 Sep 2009 09:35 by Patton.
- Eldiablo
28 Sep 2009 11:01 #324474
by Eldiablo
Will I made a new stainless pick up for the main feed. Works great. Thanks guys.
- AtLarge
- Thank you received: 21
28 Sep 2009 13:05 #324487
by AtLarge
1973 Honda CL70-K3
1975 Kawasaki 350 F9-C
1983 Kawasaki KZ750-K1
1994 BMW K1100RS
2008 Suzuki GSX1300-BKK8 #1120
Replied by AtLarge on topic Pitcock help
Bluemeanie wrote:
How do you separate this for further cleaning of the petcock?
I still can't get mine to shutoff completely when the motor isn't running.
Any suggestions on what I missed during the last two cleanings? Rebuild kit didn't help. I wonder if the spring inside just isn't strong enough to return the diaphram to shutoff position. That's the one part that didn't come in the rebuild kit.
1973 Honda CL70-K3
1994 BMW K1100RS
- Bluemeanie
29 Sep 2009 06:16 - 29 Sep 2009 06:20 #324580
by Bluemeanie
The plastic screen and tube is just hand pressed in, a little wiggle will remove it. As far as your leaking goes, I had the same problem. Here is what I found with the K&L kit.
K&L rebuild kit
Ordering OEM diaphram (which includes plastic spacer) for $12 cured my problem, seals perfect.
K&L rebuild kit
Last edit: 29 Sep 2009 06:20 by Bluemeanie.
