How many turns on the pilot jet??
  • kz550krazy
  • kz550krazy's Avatar Topic Author
18 Mar 2006 20:22
#32392
Stock 1980 kz 500.....how many turns on the pilot jet? Does anyone have all the specs?
  • kz550krazy
Re: How many turns on the pilot jet??
18 Mar 2006 20:23
#32393
Stock 1980 kz550-ooops!
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
19 Mar 2006 17:40
#32628
Mine runs about 1/2 turn out ,, but it is an 81 550A The Jet kit I used said 1/2 -3/4 turn out if that is any help . I got best idle and best off idle at the 1/2 turn out
  • kz550krazy
19 Mar 2006 19:12
#32662
Thanks a bunch for the info!
  • kz550krazy
19 Mar 2006 19:12
#32664
  • brokekz
  • brokekz's Avatar
20 Mar 2006 17:48
#32930
Is your bike running bad?
The best is to buy a manual and go from there. Some carbs tell you to turn them out for richer or leaner; you need to know this.
if you dont have access to a manual try this.
Warm up the bike real good. Then amke sure idle is et right. next pick a carb and work from one side to the other. turn the screw in or out until you reach the highest idle speed then readjust you idle . repeat this on each carb.
:woohoo: MAKE SURE you dont bottom the screw outor you will damgae the tapperd needle and seat$$$$$$$. and if you dont have any change in idle when adjusting you carb or carbs then they need work. you should see idle chang within 1/2 turns.
note. if the weather is warm where you live, put a fan next to the engine to keep it cool.
nate.
wiredgeorge is a carb expert also.
  • brokekz
  • brokekz's Avatar
20 Mar 2006 17:49
#32931
nate.
  • wiredgeorge
  • wiredgeorge's Avatar
21 Mar 2006 06:40
#33037
wiredgeorge was a bit scared to get involved in this. You don't turn pilot jets. Pilot jets are screwed in and are NOT adjustable.
I suppose this guy is talking about air screws up on the sides of the carburetors? If so, then the best answer is to warm bike, turn each 1.5 turns out from lightly seated and try and find the fastest idle for each of the carburetors, in turn. Then readjust idle speed. The exact position will vary depending on how dirty things are and what size pilot jets you have.
  • brokekz
  • brokekz's Avatar
21 Mar 2006 16:48
#33174
Thats what I thought also???????:S
  • brokekz
  • brokekz's Avatar
21 Mar 2006 16:49
#33175
  • kz550krazy
21 Mar 2006 19:04
#33228
That is what I had originally thought too....but more than one person had told me otherwise. My manual made no mention either way. They are in tight so that's how they will stay.
