z650 carbs spitting fuel into pods.
- Aumriff
25 Sep 2009 15:29 #323896
by Aumriff
KZ650 F2 (1981 UK/Euro model)
K+N Pods, Marshall 4-1 exhaust
Living in the UK
z650 carbs spitting fuel into pods. was created by Aumriff
Hi all. I'm still having problems with my z650-f2. I'm getting a lot of fuel spitting out of the carbs into the pods and then sprayed through the pods onto the electrics and battery. The floats and fuel level is within +/- 1mm of the manual spec. The main jet is a 107 and 15's for the pilot jet. Air screws are turned out 2.5 turns. I just can't work out why some of the fuel gets blown out into the pods. Any help would really be appreciated as I've had the carbs off atleast 10 times in the last month.
btw, the bike is the uk/european z650-f2 (1981)
Living in the UK
- anarki650
- Thank you received: 5
25 Sep 2009 16:19 #323902
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic z650 carbs spitting fuel into pods.
Are the float needles seating properly? If they are letting fuel by because they are worn it might cause your issues.
09 Kawasaki ER6n
Omaha NE
- Bluemeanie
- Thank you received: 14
26 Sep 2009 06:12 #324017
by Bluemeanie
Replied by Bluemeanie on topic z650 carbs spitting fuel into pods.
Is the fuel spitting out or are the carbs popping as in maybe a timing issue? First, with your 4-1 and pods I would be running 17.5 pilots and I would think maybe a little more main jet. Check your timing advancer and make sure it's lubed. Check engine timing and make sure your valve adjustment is with in spec. Bad valve adjustment can mimic other problems. Let us know...
- chance
- Life long biker/
26 Sep 2009 07:10 #324030
by chance
Replied by chance on topic z650 carbs spitting fuel into pods.
Valves not seating? Do they all blow out gas?
