Getting random bursts of gas than none
- DawnKZ750
23 Sep 2009 12:07 #323511
by DawnKZ750
1982 KZ750-E
MASSACHUSETTS
Getting random bursts of gas than none was created by DawnKZ750
Hi, I've searched the archives and couldn't find an answer. Bike idles fine, while riding it will bog and then shoot forward really quick, be okay for a little while, then do it again, very random. It seems like it's starving for gas sometimes and then gets a big shot of gas. I took the carbs off four times, cleaned w/carb cleaner and blew compressed air through all the holes. Could something else be causing this problem besides the carbs?
Thanks,
- Dawn
Thanks,
- Dawn
1982 KZ750-E
MASSACHUSETTS
- fixer5000
- Thank you received: 5
23 Sep 2009 12:14 #323512
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Getting random bursts of gas than none
fuel tank vent plugged maybe??
massachusetts
- Thank you received: 2098
23 Sep 2009 12:24 - 23 Sep 2009 12:25 #323514
by Patton
Replied by Patton on topic Getting random bursts of gas than none
Fuel starvation may also result from clogged petcock often due to crud inside the tank. Look for clogged screen on the petcock pick-up tube inside the fuel tank. May remove tank and flush it out to remove loose grit, etc.
Would also assure the in-line fuel filter isn't clogged. Fuel should flow freely through the filter.
If fitted with a manual petcock, would unscrew the sediment bowl, and assure the removable round filter screen is clean and unclogged.
But the reported issue might not be resulting from fuel starvation, and might be due to a sticking advancer unit.
If not already done, might want to first use a strobe type timing light to verify proper function of the automatic advancer unit to assure it's not sticking. With engine running, should be able to watch the advancer move quickly back and forth as rpm's are varied by blipping the throttle.
Good Luck!
Good Luck!
Last edit: 23 Sep 2009 12:25 by Patton.
23 Sep 2009 12:35 #323516
by Patton
To check for a possible fuel cap venting problem as suggested by fixer 5000, could try a test run with the fuel cap ajar (slightly open and not snapped down).
This test assures adequate tank venting during the test.
If the problem persists while running with the tank cap ajar, it's probably due to something else besides a clogged tank cap vent.
Good Luck!
Good Luck!
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
23 Sep 2009 14:23 #323534
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic Getting random bursts of gas than none
Good ideas are up on the board already. If I were you I would try them in the order of easiness. First run it with the tank open. Next take off the petcock and give it a thorough cleaning along with the tank. If niether of those work, set the petcock to prime and see if there is an improvement. If there is it means there is something wrong the vacuum lines going to the petcock or the petcock vacuum diaphragm. That is if you have a vacuum petcock. If none of these work I have more suggestions but before we go there what RPM is this happening at and at what throttle opening. does it only happen when you snap the throttle open or when you roll it on smoothly. I'm assuming this bike has CV carbs??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
23 Sep 2009 19:12 - 24 Sep 2009 03:10 #323582
by Patton
Might have an intermittent wiring problem such as a loose connector or internally frayed wire that's causing loss of continuous voltage supply to ignition coils.
For example, a short in the kill switch, or in the fuse connection where battery voltage is being sent to the ignition switch, or a short in the ignition switch itself.
Can test run with temporary wire from battery positive terminal direct to red/yellow wire feeding coil primary terminals, which by-passes the stock wiring, fuses and switches. But don't leave this hooked up while the engine's not running because that's like leaving the ignition switch in ON position.
Good Luck!
Good Luck!
Last edit: 24 Sep 2009 03:10 by Patton.
- Thank you received: 2829
23 Sep 2009 20:18 #323589
by 650ed
Replied by 650ed on topic Getting random bursts of gas than none
I know this sounds obvious, but make sure the fuel line has no tight bends or kinks. Ed
- DawnKZ750
25 Sep 2009 08:38 #323827
by DawnKZ750
1982 KZ750-E
MASSACHUSETTS
Replied by DawnKZ750 on topic Getting random bursts of gas than none
I checked the petcock, no clogs, i got another petcock off another bike, i'm going to switch them. Tried the tank open, no different. FirstI will check the wiring I did just replace a coil a few weeks back with a used one. I didn't realize that it could be a coil/wire problem.
Thanks for all your help.
1982 KZ750-E
MASSACHUSETTS
