Main jet size change
- KZ1100 Bully
23 Sep 2009 11:44 #323505
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
Main jet size change was created by KZ1100 Bully
In my Clymer book it shows that the main jet was 120R in the 81-82 model year and in 83 it went down a size to 117.5.
I was wondering why it downsized? All the other parts stayed the same.
I bought a kerker # 127-61001 I have stock Air box with K&N filter and I want to figure out what size main jet to use.
- PLUMMEN
- Thank you received: 104
23 Sep 2009 11:55 #323510
by PLUMMEN
Replied by PLUMMEN on topic Main jet size change
EPA
- KZ1100 Bully
23 Sep 2009 12:29 #323515
by KZ1100 Bully
Replied by KZ1100 Bully on topic Main jet size change
That is what I thought "EPA". So a bigger jet would help restore the some performance back before the "EPA"
Not sure what size jets to get Mikuni Large Round Main Jet
120 or 122.5 or 125 up from 117.5
- bountyhunter
- Thank you received: 337
23 Sep 2009 15:02 #323539
by bountyhunter
Replied by bountyhunter on topic Main jet size change
KZ1100 Bully wrote:
Unless they screwed with the needle's taper or something else too.That is what I thought "EPA". So a bigger jet would help restore the some performance back before the "EPA"
- KZ1100 Bully
24 Sep 2009 05:11 #323611
by KZ1100 Bully
I think I will start with 122.5 mains and see how they work. I don't think I need to make to drastic size change but I really don't know. Only way to learn is to try.
Thanks for the help so far guys.
- roy-b-boy-b
- Thank you received: 103
24 Sep 2009 07:16 #323635
by roy-b-boy-b
Replied by roy-b-boy-b on topic Main jet size change
I would have 20 idle jets while you are getting them. Roy
- KZ1100 Bully
24 Sep 2009 08:25 #323649
by KZ1100 Bully
roy-b-boy-b wrote:
I don't see any such jet in the book (idle jets):
I have a pilot jet at 40
Jet needle 4cg14
Needle Jet Y-1
and a idle mixture screw
Jet needle 4cg14
Needle Jet Y-1
- roy-b-boy-b
24 Sep 2009 09:06 #323657
by roy-b-boy-b
Sorry, I was thinking 26mm.
I have 40's in my 36's. Roy
