NEWBIE QUESTIONS ABOUT SPARK PLUGS
- waterwalker
22 Sep 2009 18:35 #323362
by waterwalker
NEWBIE QUESTIONS ABOUT SPARK PLUGS was created by waterwalker
having some trouble with my 82 kx750. its stribling bad up untill 3000rpms. i posted in the electrical category and most said i had some carb trouble. today i made a HARD run threw 3rd gear then shut the bike off and pulled the plugs. the two outer plugs were VERY VERY black(fouled i guess), and the two inner plugs were white and clean?????? any thing???? - thanks
- Old Man Rock
- Thank you received: 225
22 Sep 2009 18:41 #323365
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic NEWBIE QUESTIONS ABOUT SPARK PLUGS
Download this file... Excellent Spark Plug Chart...
kzrider.com/index.php?option=com_docman&...d&gid=448&Itemid=108
Normally.....
Black = Rich
White = Lean
When you say black... carbon/sooty or oil wet?
When you say white, are you speaking of the insulator, if so, should be a tan color not bright white....
Follow the chart, good stuff....
Also, pictures are worth a thousand words... Take some images of those plugs and someone here will jump on helping out....
OMR
Normally.....
Black = Rich
White = Lean
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- bountyhunter
- Thank you received: 337
22 Sep 2009 22:18 - 22 Sep 2009 22:19 #323431
by bountyhunter
Replied by bountyhunter on topic NEWBIE QUESTIONS ABOUT SPARK PLUGS
waterwalker wrote:
You might switch coils just to make sure you don't have a weak one before you tear into the carbs.
Then tear into the carbs....:laugh:
Rotate the plugs from inside to outside every ten miles.having some trouble with my 82 kx750. its stribling bad up untill 3000rpms. i posted in the electrical category and most said i had some carb trouble. today i made a HARD run threw 3rd gear then shut the bike off and pulled the plugs. the two outer plugs were VERY VERY black(fouled i guess), and the two inner plugs were white and clean?????? any thing???? - thanks
Last edit: 22 Sep 2009 22:19 by bountyhunter.
