- Thank you received: 2098
Best way to check intake boots?
23 Sep 2009 04:32 - 23 Sep 2009 11:27 #323444
by Patton
Replied by Patton on topic Best way to check intake boots?
Refresher: Terminology 101 ---
Sometimes the term carb boot is loosely used when referring to either the airbox intake hose located on the carb's intake side OR the carb holder located between the carb and engine.
With the stock airbox, the airbox intake hose connects the airbox to intake side of the carb.
Where the airbox has been replaced with pod filters, then the airbox intake hoses aren't used anymore.
Regardless of air filtration system on intake side of carbs (whether airbox or pods, or intake stacks or nothing), the carbs are held onto the engine by the carb holders, which carb holders are sometimes also refered to as carb manifolds.
The terms "airbox intake hose" and "carb holder" are used by Z1 Enterprizes in describing these different parts.
The critical air leak issues are usually associated with the carb holders.
Here's a pic.
Good Luck!
[Click on image to enhance view]
Here's a pic.
Good Luck!
Last edit: 23 Sep 2009 11:27 by Patton.
- JMKZHI
- Thank you received: 48
23 Sep 2009 07:00 #323463
by JMKZHI
Inlect ducts connect the carbs to the airbox.
So... carb holders & airbox ducts.
Replied by JMKZHI on topic Best way to check intake boots?
Carb holders connect the carbs to the engine.Refresher: Terminology 101 ---
- kzrider4life
24 Sep 2009 22:35 #323791
by kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
Replied by kzrider4life on topic Best way to check intake boots?
I bought new ones,figured screw it why take the chance of em being crappy.
- Old Man Rock
- Thank you received: 225
25 Sep 2009 04:55 #323803
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Best way to check intake boots?
RTV: Manifold Sealer.
Duct-Tape: Outer manifold Sealer
Gorilla Tap: Duct-Tape Sealer
Cereal Box: Float Bowl Gaskets
:blink: :huh: :dry: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
