Floats are off.
- kzrider4life
21 Sep 2009 21:38 #323138
by kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
Floats are off. was created by kzrider4life
So i pulled the carbs and when u turn them over the floats in 2 bowls hang way lower than the other 2,i would assume this is an issue!? You can tell the floats that are way lower when you turn the carbs upside down are to low. Thoughts?
- PLUMMEN
- Thank you received: 104
21 Sep 2009 21:42 #323140
by PLUMMEN
Replied by PLUMMEN on topic Floats are off.
pick up a shop manual and set em all the same.somebody was selling a tool for that a while back
- kzrider4life
21 Sep 2009 21:51 #323143
by kzrider4life
Replied by kzrider4life on topic Floats are off.
I have a book.
- Thank you received: 2098
22 Sep 2009 05:08 #323174
by Patton
Replied by Patton on topic Floats are off.
Would suggest using the clear plastic tube method to actually see the fuel level inside the floatbowl. May be performed on assembled carbs, whether or not fitted onto the engine.
The upside-down-on-the-bench measuring method to adjust float height is notoriously unreliable.
Good Luck!
Good Luck!
- Bluemeanie
- Thank you received: 14
22 Sep 2009 06:19 - 22 Sep 2009 06:21 #323185
by Bluemeanie
Replied by Bluemeanie on topic Floats are off.
PLUMMEN wrote:
Here is the carb float level tool . I need to get me one of these...
Last edit: 22 Sep 2009 06:21 by Bluemeanie.
- JR
- Thank you received: 449
22 Sep 2009 06:55 #323194
by JR
Replied by JR on topic Floats are off.
Make sure the floats are installed all the same way. It's possible to put a pair in upside down then they will be really out of whack with the rest
