Idle wont stay in one place.
- kzrider4life
21 Sep 2009 16:44 - 21 Sep 2009 16:49 #323057
by kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
Idle wont stay in one place. was created by kzrider4life
bought a bike took it for a ride when i picked it up,ran ok. Got it home wouldn't start,now i replaced the plugs and gas(old gas) Cleaned the air filters and it wouldn't start. Pulled the air filters and laid my arm across the carbs and it fired,idles ok but not smooth like it should. basically it high idles after you ride it a few and you gotta keep messing with the idle knob,figured i would pull em and clean em tonight,and advice otherwise?
Last edit: 21 Sep 2009 16:49 by kzrider4life.
- Old Man Rock
- Thank you received: 225
21 Sep 2009 17:07 #323066
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Idle wont stay in one place.
Intake manifolds dried and cracked equates to vacuum leak....
Is there an in line fuel filter?
If you pull the crabs, at least take a look inside the float bowls, should tell you quite a bit regarding their condition....
You replaced the plugs, what condition where they in?
Black, oily, sooty, white etc....
Have you checked the ignition timing?
Battery voltage?
Throttle cable & carb pulley conditions?
OMR
Battery voltage?
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzrider4life
21 Sep 2009 17:15 #323068
by kzrider4life
Replied by kzrider4life on topic Idle wont stay in one place.
It pulls like a freight train when under throttle. I pulled the carbs just now,gonna go through them tonight and clean everything. the intake boots look good,no cracks that i can see. Will see what the bowls look like tonight and clean all jets and so on. Timing is good on it,it sat for a long while tank had that old gas smell so i am thinking the carbs just need a good going through hopefully.
- tinlizzie37
- Thank you received: 1
21 Sep 2009 18:57 #323094
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic Idle wont stay in one place.
Make sure you put on a good cycle filter as Old man Rock mentioned. It'll save you from doing them over and over. Bob
- TeK9iNe
- What did you do!?!
- Thank you received: 28
21 Sep 2009 21:16 #323136
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Idle wont stay in one place.
Old Man Rock wrote:
CRABS, really? LOL! :laugh:
If you pull the crabs...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
