KZ 650 Idle mixture screws. PLEASE HELP
- YUKABODOS
21 Sep 2009 13:30 #323017
by YUKABODOS
KZ 650 Idle mixture screws. PLEASE HELP was created by YUKABODOS
So..... if I want to richen up the mixture a little, would I turn the screws clockwise or counterclockwise? Will I need to resync the carbs afer tweaking the idle screws? I just had them synced 2 weeks ago.
I have heard that the idle circut contributes to the fuel flow until the main takes over and I would like to richen up the bottom end after a 4 into 1 install on a stock set up.
Yuabodos Buddy!!!
:blink:
Yuabodos Buddy!!!
:blink:
- Thank you received: 2098
21 Sep 2009 17:27 - 21 Sep 2009 17:28 #323069
by Patton
Replied by Patton on topic KZ 650 Idle mixture screws. PLEASE HELP
YUKABODOS wrote:
For manual slide carbs (not CV carbs) ---
Side located pilot air adjuster screw turns in clockwise to enrichen.
Bottom located pilot mixture adjuster screw turns out counter-clockwise to enrichen.
Should not require re-sync.
Good Luck!
Yuabodos Buddy!!!
:blink:
Good Luck!
Last edit: 21 Sep 2009 17:28 by Patton.
