Which float bowl drain plug O rings?
  • ckotul
  • ckotul's Avatar Topic Author
21 Sep 2009 07:34 - 21 Sep 2009 07:36
#322971
This weekend I noticed that the drain screws on two of my float bowls have a very slow leak on my '77 KZ650C. I'm guessing that bad o-rings are to blame, but I'm not sure which ones to get. Can someone point me in the right direction? Here's the list of o-rings available from Babbitts. The SKU #'s are all the same, but they say that they're for different carbs??? Thanks!
SKU: 16038-016 "0" RING,MAIN JET CO (for 16001-1020)
SKU: 16038-016 "0" RING,MAIN JET CO (for 16001-1022)
SKU: 16038-016 "0" RING,MAIN JET CO (for 16001-1069)
SKU: 16038-016 "0" RING,MAIN JET CO (for 16001-1084)
1977 KZ650C1
Last edit: 21 Sep 2009 07:36 by ckotul.
  • JMKZHI
  • JMKZHI's Avatar
Re: Which float bowl drain plug O rings?
21 Sep 2009 09:14
#322985
Uh, aren't those main jet o-rings?
It's just a drain screw. HarborFreight & other places sell metric nitrile o-ring kits for about $10. The kits will have one or two that'll work fine. Some auto parts stores sell individual o-rings from a similar kit.
  • ckotul
21 Sep 2009 09:36
#322988
The main jet o-rings and the drain plug o-rings are the same. Thanks for the tip about the kits.
1977 KZ650C1
21 Sep 2009 09:37
#322989
Might also take one of the remaining good o-rings to attempt matching up at the local hardware store.
Good Luck! :)
  • Mcdroid
  • Mcdroid's Avatar
  • Online
  • Gone Kwackers
21 Sep 2009 09:53
#322990
Try to get nitrile o-rings as the 'new' gasoline w/10% alcohol is tough on OEM style o-rings.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • JMKZHI
  • JMKZHI's Avatar
21 Sep 2009 12:04
#323009
Also, the kits are handy because several other sizes can be used on the carbs & elsewhere on the bike.
21 Sep 2009 18:31
#323088
Kawasaki part number is 16038-016, these are still available from Kawasaki for a little over $1 each. Ed
  • tinlizzie37
  • tinlizzie37's Avatar
21 Sep 2009 18:47
#323092
It will be a lot cheaper with a Harbor Freight metric o-ring set as one of the guys mentioned. I used them on my 650 LTD and all fit fine.You can't go wrong for the price. Bob
Bob KZ 650 E1, En 450
  • ckotul
22 Sep 2009 11:57
#323249
Thanks for the help! I ordered the 225 piece kit from Harbor Freight today.
1977 KZ650C1
