best way to clean a set of k&n's?
- kzrider4life
20 Sep 2009 16:18 #322814
by kzrider4life
Current bike..1977 kz1000 1075cc kit,dyna everything,lotsa chrome,kerker pipe.
best way to clean a set of k&n's? was created by kzrider4life
never had pods filters so i need to know the best way to clean em.
- sbulla
- 1980 KZ1000 LTD
20 Sep 2009 16:25 #322815
by sbulla
Now----
1980 KZ1000 LTD (Kerker 4-1, K&N pods, Dyna gray coils)
Gone but not forgotten----
1966 Honda 305 Superhawk
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
1995 HD Sportster 1200
2000 HD Softail
2002 KLR650
Replied by sbulla on topic best way to clean a set of k&n's?
kzrider4life wrote:
Don't know if it's the best way but, I've always used Simple Green. Just soak 'em, let 'em sit for a few minutes and then run warm water through from the inside to out to rinse them.
To dry them, sling as much water out as you can and set 'em in front of a fan and take a nap. They say not to try and rush the drying with hot air as it will damage them.
My .02...
Sonny
My .02...
Sonny
Now----
1969 HD 350 Sprint
1971 500 H1
1972 250 F8
1972 750 H2
1973 KX250
2000 HD Softail
2002 KLR650
- PLUMMEN
- Thank you received: 104
20 Sep 2009 16:30 #322817
by PLUMMEN
Replied by PLUMMEN on topic best way to clean a set of k&n's?
409 works also
- JR
- Thank you received: 449
21 Sep 2009 17:55 #323073
by JR
Replied by JR on topic best way to clean a set of k&n's?
K&N sell a cleaner spray bottlealong with the oil spray. Both can be purchased in a Recharge Kit. You just follow the instructions, spray on the cleaner, let sit for the required time and rinse well with tap water. No pressure. Allow to air dry and spray on the oil.
I'm sure I have used Simple Green in the past. Spray, let sit for a while, rinse well and air dry.
- Thank you received: 2237
21 Sep 2009 18:03 #323075
by TexasKZ
Replied by TexasKZ on topic best way to clean a set of k&n's?
What JR said.
- kzrider4life
21 Sep 2009 18:04 #323077
by kzrider4life
Replied by kzrider4life on topic best way to clean a set of k&n's?
i did the simple green thing,seemed to make em cleaner.
