KZ750 Carb - Remove Diaphragm / Slide Assembly?
- conkdor
20 Sep 2009 16:16 #322813
by conkdor
KZ750 Carb - Remove Diaphragm / Slide Assembly? was created by conkdor
I just purchased a KZ750 project bike and I'm cleaning the carbs. The repair manual that I have says to remove the diaphragm / slide assembly. Can someone tell me how to do this with out damaging the diaghragm? It doesn't seem to want to come out. Thanks - Dave
- JR
- Thank you received: 449
20 Sep 2009 18:22 #322873
by JR
Replied by JR on topic KZ750 Carb - Remove Diaphragm / Slide Assembly?
Is the bike a 750/4 with Keihin CV34 of Mikuni BS34 carbs ?
So. you have the tops off and the spring out ? What's stuck ?
Will the slide move up and down or is it stuck ?
The egde of the diaphrams fits into a groove in the carb body just under the chromed top. Is this stuck? Dried up gas/gum ? Whatever you do dont put carb cleaner here. I dont think carb cleaner will be good for the diaphragm. I'm not sure what to suggest. Maybe WD40.
- Thank you received: 2098
20 Sep 2009 18:39 - 20 Sep 2009 18:41 #322884
by Patton
Replied by Patton on topic KZ750 Carb - Remove Diaphragm / Slide Assembly?
Hello, David, and WELCOME to KZR!
We're glad you're here!
Here's the link to a pretty good article about refurbishing CV carbs.
Might find some helpful info.
Click here > CV Carb cleaning with Pics
Good Luck!
Good Luck!
Last edit: 20 Sep 2009 18:41 by Patton.
