carbs run out of fuel
- 80kzrdr
19 Sep 2009 19:18 #322585
by 80kzrdr
carbs run out of fuel was created by 80kzrdr
I have an 80 kz650 csr. I run a v&h pipe. Have pod filters. I had a stge #3 jet kit put in. The problem happens when I do a hard start or wheelie. The carbs seem to run out of fuel. Another issue is when I run premium fuel it runs like shit. I would like to run drag fuel when I am at the track. I get the best times when I run 87 octain. Any help would be great.
- timebomb33
- Thank you received: 10
19 Sep 2009 19:24 #322587
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic carbs run out of fuel
double check your float heights it sounds like they might be off a bit if it's running bad on premium it might be due to high alcohol content in the fuel also if your ignition plate is adjustable give some more advance. if your premium fuel is high in alcohol then you will have to richen up your main jets a few sizes. by the way welcome
- kawsakiman
- Thank you received: 6
19 Sep 2009 20:58 #322599
by kawsakiman
Replied by kawsakiman on topic carbs run out of fuel
buy a pingel fuel valve and install it after you check what tb said.
