What's this gizmo for? 78 KZ1000 A2A
- ridejunkie
19 Sep 2009 17:52 #322577
by ridejunkie
'78 KZ1000 (sold 9/10/11, I feel like I'm missing a limb)
'83 BMW R80RT
'90 EX500 fantasy racer "Pearly"
'06 EX500R Ninja sport tourer
"There's no such thing as a $200 motorcycle."
What's this gizmo for? 78 KZ1000 A2A was created by ridejunkie
OK, newbie questions never stop, even three years in. On the second carb in from the left, there is a hose fitting (looks like brass) that exits up, kind of left and rearward.
what does this do? I'm running a non-vacuum non-OEM petcock, so is this yet another vacuum fitting for me to cap? I finally blocked off the one on the next carb over and it gave me a hell of a performance boost over when I pulled the bike out of the PO's garage sale.
Gimme a shout and hep me out. Thanks in advance.:silly:
'83 BMW R80RT
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
19 Sep 2009 18:18 - 19 Sep 2009 18:19 #322579
by Skyman
West Linn, OR
Replied by Skyman on topic What's this gizmo for? 78 KZ1000 A2A
Are these VM26 carbs we're talking about here?
If so, there should be two of these. One on #2, and one on #4. They are NOT vacuum ports, but are vents. You should run a hose from these two ports back into the area under the seat, above the airbox.
Here's a good reference for you:
www.wgcarbs.com/index.php?option=com_con...view&id=17&Itemid=32
Oh, yeah. And welcome to KZR!
West Linn, OR
Last edit: 19 Sep 2009 18:19 by Skyman.
- timebomb33
- Thank you received: 10
19 Sep 2009 19:40 #322589
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic What's this gizmo for? 78 KZ1000 A2A
they have to be vented to the atmosphere in order for the carb's to work don't cap them off.
- ridejunkie
19 Sep 2009 20:25 #322594
by ridejunkie
'83 BMW R80RT
Replied by ridejunkie on topic What's this gizmo for? 78 KZ1000 A2A
Thanks, Skyman. Excellent link for my needs. So far, so good. I can add some vent lines. My main concern was that it need not be capped.
Back to work.
Back to work.
'83 BMW R80RT
- timebomb33
19 Sep 2009 20:31 #322596
by timebomb33
by the way welcome to our world i never noticed that you where new on here if there is any thing else that you need help with on your bike there are a ton of guy's that you can get help from.
- Thank you received: 2098
20 Sep 2009 01:26 #322613
by Patton
Replied by Patton on topic What's this gizmo for? 78 KZ1000 A2A
ridejunkie wrote:
Some carb sets do include a 5th vacuum nipple for a hose to the petcock. Such nipple closely resembles the 2 floatbowl vent nipples (which aren't capped, and exit to open air, usually by tubes routed under the seat or under the bike).
Where a manual petcock is fitted, the 5th vacuum nipple isn't used, and should be capped (same as the other 4 vacuum nipples).
See example below.
Good Luck!
[Click on image to enhance view]
...On the second carb in from the left, there is a hose fitting (looks like brass) that exits up, kind of left and rearward.
what does this do? I'm running a non-vacuum non-OEM petcock, so is this yet another vacuum fitting for me to cap?....
See example below.
Good Luck!
