1981 KZ305
- homulous
19 Sep 2009 13:54 #322535
by homulous
1981 KZ305 was created by homulous
Hello, I just picked up a 1981 KZ305 and am having some issues with the carbs. Theyre Kei Hin carbs, just got them cleaned and checked and the mechanics said the once I got the stock air filter it would run right. Well I can't get the idle set right and it is still bogging out when I get on the throttle.
I would like to change to POD air filters and cut off the mufflers. What should I do?
- PLUMMEN
- Thank you received: 104
19 Sep 2009 14:12 #322537
by PLUMMEN
Replied by PLUMMEN on topic 1981 KZ305
welcome to z-jungle! id leave the exhuast and stock airbox alone.when was last time the bike was tuned up? its really easy to open a big can of worms ,id check basics first
- homulous
19 Sep 2009 14:43 #322548
by homulous
Replied by homulous on topic 1981 KZ305
Cool,I just got it tuned up and the carbs cleaned. It has a new battery, new air filter, changed the oil and checked all the electrical, I don't know what the deal is.
- Locozuna
19 Sep 2009 15:26 #322557
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic 1981 KZ305
If he said it would be alright with a new air filter and you just put in an air filter and it's running poorly I'd go back to him. Sounds like he didn't get the carbs cleaned thoroughly. Check plugs (?points?) and electrical connections. Might also check compression and timing but sounds like carb problems. Also you should leave your mufflers and airbox alone. At least until you have it running right. Those two things have rendered many good running bikes into nightmares. Especially when one is just learning. GLuck!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Old Man Rock
- Thank you received: 225
20 Sep 2009 06:37 #322640
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic 1981 KZ305
Pictures of this old and rare beauty?
Not sure but I would think this old girl would be worth more stock... I'm probably wrong though... :blush: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
