carb bowl
  • michigans
  • michigans's Avatar Topic Author
carb bowl
18 Mar 2006 13:49
#32252
i have a kz1000, three of the bowls have a small clip with a pin on the outer edge but the other does not (carb 4 i believe). should there be a pin and clip on this one also? looked in books and do not see this clip and pin anywhere on diagrams. this is where the gas lines connect each carb and come into the bowl
  • btchalice
  • btchalice's Avatar
Re: carb bowl
18 Mar 2006 16:23
#32293
can you get pics?
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • michigans
Re: carb bowl
18 Mar 2006 16:30
#32298
no camera not here right now. there is a small bearing type ball and about an 1/8" long rod x 1/16"long which is held in place by the clip. also been doing lots of research today and found out these are 26mm carbs.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: carb bowl
18 Mar 2006 18:58
#32379
Maybe looking on BuyKawasaki.com under parts diagrams would help?
Put your model number and year in your signature. Here's a link for an '81 1000 Police model...
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • The Fish
  • The Fish's Avatar
Re: carb bowl
19 Mar 2006 04:55
#32446
From your description, it sounds like the check valve for the accelerator pump. If so , all 4 will need the ball,small brass rod thing and the small spring clips. The spring clips can be made from the spring from a ball point pen. The accelerator pump rebuild kit only comes with 1 clip. 1 ball and 1 brass thing.
The accelerator pump carbs will have a lever attached to the throttle cam to the bottom of 1 carb and the float bowls will have small hoses connecting the bowls together.
Fish
  • michigans
Re: carb bowl
19 Mar 2006 07:12
#32461
wow i grew up in south lyon and thanks for the link
  • michigans
Re: carb bowl
19 Mar 2006 07:16
#32463
yep found out that is what it is. does it have to have that to run correctly?
  • The Fish
  • The Fish's Avatar
Re: carb bowl
21 Mar 2006 05:53
#33027
Yes, all 4 bowls will need the ball, brass thing and spring to run correctly. If the springs (clips) are not present, the brass thing can be pushed up and block the fuel from getting into the carb when the accel pump is used.
Fish
