Starts with difficulty and wont stay running
- chadeastin
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- mzandmz
New to Family, 1979 KZ440 LTD
- timebomb33
- wes_scooter
when you had the carbs off the second time did you soake them in carb solvent and blow out all the small holes. mainly the ones for the slow speed circuit. if it runs with choke but not without its almost always the pilot jets being pluged, at least it has been for me.
76' kz900
70' yamaha R5
2006 wr450f
- keith1
- Thank you received: 2
PODS ARE BAD MODS. There are alot of Pod Haters and there are alot of pod heads.Punny Huh. If you didn't rejet it for pods then its not going to help your problem. I am a stocky Jocky. It was made that way by people who spent lots of time and trials to get it to run good stock. Best left alone or buy a Harley. Someone who has had the same problem will be with you shorty.
pods are not bad mods....how many drag bikes have ya seen with stock air boxes?....pods are just one part of the equation in making a bike faster.....
- Buda
kzrider.com/index.php?option=com_kunena&...w&catid=13&id=320150PODS ARE BAD MODS. There are alot of Pod Haters and there are alot of pod heads.Punny Huh. If you didn't rejet it for pods then its not going to help your problem. I am a stocky Jocky. It was made that way by people who spent lots of time and trials to get it to run good stock. Best left alone or buy a Harley. Someone who has had the same problem will be with you shorty.
Pods are almost as bad as running old air in your tires.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- Old Man Rock
- Thank you received: 225
Please, you must be joking....
What next, Velocity stacks are crap as well compared to OEM filters.... :blink: :S
Sure you'll have to re-jet, wonder why, oh that's right, increased air flow.... :S
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- chadeastin
- fixer5000
- Thank you received: 5
just plain wtf??? forget the meds today?
1978 kz650b pretty much stock
massachusetts
- Thank you received: 2098
Ok, Ok, I didnt mean to start an argument about pods..... just wondering. The answer for me is to go back to stock, because I cant afford the 140$ jetting kits out there. What I have discovered by doing some more reading here is that I need to get a rebuild kit just in case my float needle is bad. However it seems to me that my bike would actually run if it were just a matter of flooding????? Some help here. could it be flooding sooooo much that it wont even run?
Based on the initial report, imo "flooding" likely isn't an issue. Chances are the existing float valves and floats remain perfectly serviceable, as is often the case. And a "rebuild kit" may not be needed. Perhaps no new parts will be required.
Would concur with timebomb's advice about the carb primary circuits not yet being thoroughly clean.
Good Luck!
- chadeastin
