- Thank you received: 7
Petcock for 900b1?
- Jimbo302
Can I get a manual single fuel line fuel valve and just "T" it off into my existing two lines?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- Jimbo302
Yeah, but they cost about $100 more than I want to spend. lol.get a pingel dual outlet and you won't ever regret it a very high quality product.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Mcdroid
- Gone Kwackers
- Thank you received: 318
I need to replace the petcock on my '76ltd and I'm curious if there is an economical option. I have a non vacuum, dual fuel outlet setup.
You can get a Pingel high volume single outlet and 'T' it but they also are still about $100...but they are worth it.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- Jimbo302
Thanks, that is exactly the info I was looking for, as I was looking at the z1 parts as well. I was just looking for an alternative to sourcing out another 30yr old used part.i have the cheap one from z1 enterprises for a thread on kz 900...i gotta say it meets my needs ,is shiny,seems well made and strong material,and cost about 13-15 bucks....so who knows...i did have to re-contact them for a rubber diaphram that was torn when it got to me(it did not shut fully off)...2 minute job...they sttod behind the product...sent one in the mail in two days......one year later ..it is like the day i bought it and it gets turned off and on a lot ,so would have failed by now....no complaints....i want a pingle but am satisfied for now...good product
- Jimbo302
Still not economical though. If T'ing it off will work, I believe I will just get the cheaper single outlet. My plan is to eventual build this bike into a nice ride, but for right now, I want to get it together to ride on the cheap.Jimbo302 wrote:
- Thank you received: 2098
May run a single inline fuel filter between petcock and Tee. Or run two inline filters, being a separate filter in each of the dual lines.
Good Luck!
- Jimbo302
Petcock to Tee, then dual lines to carb intakes, run two inline filters, being a separate filter in each of the dual lines.
Good Luck!
This is exactly what I was thinking, I ran more line and a filter on my last bike to give it more reservoir for full throttle runs.
Thanks!
- chance
- Life long biker/
