Cabs that fit KZ750
- rayellis
10 Sep 2009 11:11 #320429
by rayellis
Cabs that fit KZ750 was created by rayellis
I was looking at my carbs and started cleaning them. It looks to be a lot of work but I was wondering what other carbs would fit a 1980 KZ750E? I have the stock kehin cv34 on it now.
Thanks
Thanks
- JR
- Thank you received: 449
10 Sep 2009 12:19 #320459
by JR
Replied by JR on topic Cabs that fit KZ750
The kz750/4 also came with Mikuni BS34. The 80 had the Keihins and I think perhaps the 83 model had the Mikunis.
Dont let a bit of work scare you off. Usually worth it in the end.
Good luck
Good luck
- rayellis
10 Sep 2009 16:20 #320504
by rayellis
Replied by rayellis on topic Cabs that fit KZ750
I would rather keep these and do the work but as I get into it I'm thinking that I might have to buy some replacement parts for these carbs.Who knows how much I might spend fixing these!!!!!!!!
Thanks
Thanks
- timebomb33
- Thank you received: 10
10 Sep 2009 16:34 #320507
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Cabs that fit KZ750
anything you end up spending to get those right will be money well spent if you buy a set of used carbs from somewhere how much will you end up spending to get them right also if you buy a set that is from another type of bike how much time and effort and money will it take to get them to work properly if the bike is mostly stock your better off staying with the stock carb's and fixing those if you have done extensive modifications then by all means go after bigger badder carb's
- rayellis
10 Sep 2009 20:04 #320564
by rayellis
You are right. I don't really want bigger/better carbs I just want good stock carbs.
Here is a question for ya I'm cleaning the bowls of the carb and the copper tube is split down the middle on three of these bowls is this the way they are made? Did they crack from cleaning?
- JR
11 Sep 2009 14:04 #320721
by JR
I think those are the overflow tubes and they are brass. They do split sometimes. If the bike was laying up outside for a while moisture in the tubes can freeze and cause the split. Obviously any gas in the bowl will leak right out.
I had a split in one of mine when I got it first. JB Weld can work if you dont have to put a lot on and if you leave it 24 hours to cure. What I did was to bring a bowl to a local hobby store and find and buy a thin brass tube with a diameter such that it would just fit over the tube in the bowl. Then I cut same length, slipped it on and soldered the bottom for a permanent and economical fix. Whatever you do just make sure you dont interfere with the operation of the floats.
Good Luck
Good Luck
- timebomb33
11 Sep 2009 16:04 #320787
by timebomb33
i second what JR said it should be relitivly straight forward fix.
- rayellis
11 Sep 2009 22:23 #320860
by rayellis
Thanks guys I will fix with JB weld sounds great!! I might have blew some air in there with compressor but I would think there was a crack already there. Anybody every had this happen with just blowing air in the bowl overflow?
If so please stop I know I will !!!!!!!!:woohoo: :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
Thanks
Thanks
