- Thank you received: 103
anyone use these pods?
- roy-b-boy-b
kuul beans. I'm gonna get em. Where is the best place to buy jets for my carbs? Z1E doesnt seem to have them...would I just go to mikuni? (BS34)
Call Rob or Jeff @Z1enterprises. He has Mikuni Jets for 34's. Roy
- aaron3874
One problem with the Emgo filters is that they will block the flow of air to the diaphragm chamber if you have CV carbs. I solved the problem by cutting away rubber material inside the filter.
Using the stock pipe should be ok, but you will gain power if you let it exhaust more air.
- 9am53
- homebrew, and some bbq
- Thank you received: 3
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- keith1
- Thank you received: 2
yep
- keith1
I use the Emgo pod filters off ebay. You will need to raise the size of main and pilot jets in the carbs. If DynoJet sells a jet kit for your bike, that's an easy way to go. If not, I believe my jets were from Sudco. The local Kawi shop where I live sells jets also.
when i ran bs 34 s going from emgo to k and n made a diff...bike ran much better even though i had clearanced out the emgo s for the air jet...just my .02
- 9am53
'84 GPz900r
'71 CB350
- Buda
The chamber is at the top of the inlet of the carb, it has to do with the slide moveing.One problem with the Emgo filters is that they will block the flow of air to the diaphragm chamber if you have CV carbs. I solved the problem by cutting away rubber material inside the filter.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- 9am53
Tom
And the K&N's don't block this chamber wheras the cheaper ones do?
'84 GPz900r
'71 CB350
- Buda
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- 9am53
'84 GPz900r
'71 CB350
- Pfaelzer
1977 KZ 1000
Queen Creek, Arizona
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
