- Thank you received: 3
ultrasonic cleaner
- z19OO
08 Sep 2009 10:48 #319880
by z19OO
1975 z1 900
1979 kz650b
ultrasonic cleaner was created by z19OO
Been thinking of getting one.......I'm guessing I'll need a 7 gal. model for a rack of 4 carbs. Pro's/Con's?? Seems like a lots of choices, if i'm going to spend the $$, I want a good one.
1975 z1 900
1979 kz650b
- TeK9iNe
- What did you do!?!
- Thank you received: 28
08 Sep 2009 15:13 #319944
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic ultrasonic cleaner
What are they asking for one?
I tried boiling carbs, tank full of solvent and a massager underneath, blah blah...
the only thing that really worked was good old carb cleaner and powerful compressed air.
Well, that and a bottle of seafoam. That stuff is the $%&!
It really works!
Cheers.
It really works!
Cheers.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- fixer5000
- Thank you received: 5
08 Sep 2009 16:28 - 08 Sep 2009 16:28 #319967
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic ultrasonic cleaner
i think if i was gonna buy one id go with branson. theyre the best out there for ultrasonic stuff be it plastic welders or cleaning tanks. these were done in a big branson tank where i work...2 hours at 180 degrees with a water based cleaner
massachusetts
Last edit: 08 Sep 2009 16:28 by fixer5000.
- KawiConvert
- Thank you received: 4
08 Sep 2009 19:50 #320036
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic ultrasonic cleaner
I tried one and didn't get near the results shown above. IMO carb cleaner is the way to go, but whatever floats your boat. BTW a 1 gallon will take a full carb. You'll have to separate the rack.
- PLUMMEN
- Thank you received: 104
08 Sep 2009 21:05 #320059
by PLUMMEN
Replied by PLUMMEN on topic ultrasonic cleaner
5 gallon bucket of carb cleaner with a basket in it,and a fish tank pump with hose running to bottem of bucket to keep things stirred up.did i mention im a cheap bass-turd? :laugh:
- TeK9iNe
09 Sep 2009 06:57 #320122
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
PLUMMEN wrote:
+1 :laugh: Ditto!!
+1 :laugh: Ditto!!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- timebomb33
09 Sep 2009 07:17 #320124
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic ultrasonic cleaner
if your doing a lot of carbs like as in making a living doing they are a great idea but if your only doing a few sets over the course of a lifetime then the expense is not really worth it, if you only have one or two heads to get done you won't go and buy a set of seat cutters the price of them is so high it just dosen't make sense unless your doing it for a living.
- avidflyguy
11 Sep 2009 17:32 #320804
by avidflyguy
Replied by avidflyguy on topic ultrasonic cleaner
if you are doing 1 carb at a time,1 gallon can of berryman's carb dip with basket, doesn't seem to bother rubber too bad, whole rack of carbs,i use chemdip's parts cleaner solution, but need to take all rubber parts off appears to be water based,but it smells and it doesn't go away for a while. but it does work really good
