vacuum lines?
- clutch85
06 Sep 2009 14:05 #319526
by clutch85
vacuum lines? was created by clutch85
hello i have a kz440 and i am wanting to know if it would be ok to bypass the vacuum lines and use a different petcock than factory. Also if it is, would i just seal up the vacuum hoses or what
thanks for all comments!
- muddy1
- 1980 Kz1000 LTD B4
06 Sep 2009 17:30 #319591
by muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
Replied by muddy1 on topic vacuum lines?
Yes you can use a new petcock without the line. Plug off the vacuum line and install the new, make sure your new valve has a reserve function.
muddy1
muddy1
1970 SL-70
1972 CB 750
1976 YZ 125
1976 KZ400
1979 KZ400 LTD
1980 KZ1000 LTD B4
1984 YZ 490
1989 750 Ninja
- chance
- Life long biker/
06 Sep 2009 17:46 #319598
by chance
Replied by chance on topic vacuum lines?
You can get rubber caps to seal them and looks much nicer What other petcock can you use that dosn't use vacuum beside a pingle?
- JMKZHI
- Thank you received: 48
06 Sep 2009 19:57 #319620
by JMKZHI
Replied by JMKZHI on topic vacuum lines?
Just in case... The auto parts store will have vacuum caps.
- Thank you received: 2098
