- Thank you received: 12
Im pulling my hair out......argh
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- ArthurGoVroom
- I'd rather ride it than shine it
1976 KZ900A4, 4-1 header, rear lowering kit, grab bar removed, still shining and painting parts as time permits
- Thank you received: 2237
Plugged low speed jets and passages? Has it been parked for a while?
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
- Thank you received: 225
The following chart is for larger displacement engines but the carbs should be close to the same in OEM jetting... I think anyways, other KZ650 owners can chime in for sure....
Actually, where's Blue Meanie or Kawisakiman.. PM them...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- trianglelaguna
- Thank you received: 235
TexasKZ wrote:
Also if you turn off the choke it dies.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- TeK9iNe
- What did you do!?!
- Thank you received: 28
If compression is way off it will never run right.
maybe adequately, but not right.
Make sure to perform a good bench sync on the carbs after cleaning them out with carb-cleaner and compressed air.
Check all the fuel heights with the carbs on the bike, as fuel height is absolutely critical to performance.
Oh yeah, get a manual. It pays for itself in the first repair!
Cheers, and goodluck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
