Cant get the idle down!!!!!!!!!
- cricketfire46
02 Sep 2009 18:26 #318702
by cricketfire46
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
Cant get the idle down!!!!!!!!! was created by cricketfire46
pulling off the carbs, cleaning them, getting them bench synched i have worked out all the issues with cylinders not firing. I can actually keep a set of plugs for more than a single tank of gas without fouling them up. next problem here is that for whatever reason, once warmed up the idle stays around 4k:blink: . I have turned the idle set screw all the way out. anyone with any ideas please help.
- Thank you received: 2237
02 Sep 2009 18:41 #318718
by TexasKZ
Replied by TexasKZ on topic Cant get the idle down!!!!!!!!!
Could be throttle cables hanging up - check and lube carefully.
Throttle linkage hanging up - check for weak springs, loose screws, bent bits, gunga.
Air leak between carb(s) and head - start bike and carefully spray brake cleaner (some use wd40) around where each carb goes into its manifold and where each manifold contacts the head. A sudden change in rpm will indicate a leak.
If they are cv carbs, does each slide go up and down easily and smootly?
Is the enrichener (incorectly called choke by some)working properly, that is does it actually close when the lever is pushed to the off position?
Maybe lack of solar flares.
Good luck, it's probably something simple.
- Thank you received: 2829
02 Sep 2009 18:42 #318719
by 650ed
Replied by 650ed on topic Cant get the idle down!!!!!!!!!
Where as the idle thumb screw set when you bench synched them? If it was not in the center of its range, you may have lost the ability to use it to turn down the idle speed. Ed
- sarge383
03 Sep 2009 17:22 #318949
by sarge383
kz 650d2 sr 79
Replied by sarge383 on topic Cant get the idle down!!!!!!!!!
check and make sure your throtle cables are adjusted properly might be keeping the slides open a bit.
kz 650d2 sr 79
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
04 Sep 2009 13:22 #319098
by Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
Replied by Becker on topic Cant get the idle down!!!!!!!!!
I'm gonna say its either a cable problem or they were bench synced out of range. Remember, bench syncing is only supposed to be used so that the engine will run well enough that the carbs can be synced properly once they are on the bike.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- cricketfire46
04 Sep 2009 22:54 #319192
by cricketfire46
Replied by cricketfire46 on topic Cant get the idle down!!!!!!!!!
so far from checking, no leaks to the head... no weak springs... cables all seem to be fine... and as far as i can tell from checking the butterflies are closing properly... do i need to pull them off again and do it all over again with the idle screw tighter so that i can back it off more???? i checked them originally with a guitar string and with the idle screw set to about 1/4 of the way in Thanks in advance as this has already given me so many different possibilities
