Oh oh... When petcock rebuilds go bad... HELP!
- The_Raven
01 Sep 2009 08:39 #318200
by The_Raven
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
Oh oh... When petcock rebuilds go bad... HELP! was created by The_Raven
Howyadoin,
I just rebuilt my petcock and put it back on the mostly drained tank. When I turned the petcock to the ON position and turned the tank over, fuel was flowing from the output. If the tank is disconnected i.e. no vacuum, there should be no output, right?
What did I do wrong? I replaced the diaphragm and spring, replaced the rubber seal behind the ON-PRI-RES switch, it went back together with no issues. Arrgghh...
-Mark P.
Salem, MA
- JMKZHI
- Thank you received: 48
01 Sep 2009 08:45 #318202
by JMKZHI
Replied by JMKZHI on topic Oh oh... When petcock rebuilds go bad... HELP!
What brand are the parts? Are they Made in Japan?
- The_Raven
01 Sep 2009 09:55 #318230
by The_Raven
-Mark P.
Salem, MA
Replied by The_Raven on topic Oh oh... When petcock rebuilds go bad... HELP!
Got it... I had the spring on the wrong side of the diaphragm. :blush:
It looks to be working good now, no leaks.
I'm such a maroon... :S
P.S. I got the kit from Z1 Enterprises. Perfect fit, and man do they ship fast! Kudos to them!
-Mark P.
Salem, MA
