- Thank you received: 8
wow another carb question SHOCKING
- donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- roy-b-boy-b
- Thank you received: 103
- Old Man Rock
- Thank you received: 225
"popping while idling, popped on deceleration"...
Are both conditions of running too lean...
popping while idling:
In reviewing my project, to get through emissions, I had tweaked my slow jets (Keihin for pilots) to far out for lean operations at idle...
Once in the bay, I couldn't get it to start or idle at all with out being on the throttle... Spit, back fire you name it... Not allowed in the test, she has to be able to idle during the test...
So rolled the old girl out of the bay, tweaked the slow jets 1/4 turn in for richer operations, went back in line and passed with flying colors. After the test, tweaked them back in 1/2 turn (richer) for normal driving...
popped on deceleration:
Sure could be an exhaust leak in the system or vacuum leak for that matter but if carb related, get your mains corrected first... Meaning if no falling on it's face in WOT response then mains most likely on or at least close to on the spot.
While driving 1/2 to 3/4 rpm range, let the throttle snap back to close, if pops or pop-=pop-pop during decelerations, then most likely still a little lean on the clip position... Change one position for richer operations and test ride her again.
Set jets to normal manual specs... Start with mains first, then needle jet clip position then go after your pilots... Only do one at a time in this sequence otherwise you'll be chasing this for a really long time.
Hope this helps, worked for me in learning the fine art of carb tuning...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- donthekawguy
Have you check your valve clearance latley? Roy
Maybe three hundred miles since I did them.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- donthekawguy
This is what I've been taught and have learned from my two friends/mentors...
OMR
I'll have to print this out for sure. With the bike going like a raped ape when I open the throttle and the good plug condition I'm thinking I'll leave the mains alone. I was a little surprised to find 107.5's in there but that's the stock size. The more I look at the rubber bits all over the bike the more I find to replace so I'm going to order a new set of manifolds and boots. I'll also try moving the needles one clip. I don't want to mess with it too much because I'm getting a new exhaust this winter and might have to go through it all again.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Old Man Rock
A little tip I learned from Larry.... Set the idle as low as possible 500-800rpm... Then sync for the +/-2cmHg...
After completing, then adjust back up to normal operations 800-1000rpm... Possibly higher....
Note: Depending on your engine builds (as in my case) my motor doesn't like the idle specification range 800-1000rpm. Both Plummen and Larry stated this to me where that range was intended for stock motors, not modified performance engines where you have head over sizes valves, port & polished intakes, performance cams and increased compressions etc....
Ahhhhhhhhhhhhhh, makes sense;) ....
My engine idles @ 1100-1200 nicely, just where she wants to be....
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
