help with some jets
- kz750ohio
31 Aug 2009 11:21 #317907
by kz750ohio
1982 kawasaki kz750 with mikuni carbs bs34, stock everything else.
help with some jets was created by kz750ohio
I have a 1983 KZ750 LTD that I bought from a guy a little while back. He put Mikuni BS34 carbs on it that he said came from a GPZ 750.
I am going to upgrade the exhaust to a V/H 4 into 1 and needed to know what jetting size I will need for it. I also noticed the needle jet has a clip on it so does it need to be adjusted too.
let me know and thanks,
max
max
- bountyhunter
- Thank you received: 337
31 Aug 2009 11:58 - 31 Aug 2009 11:59 #317916
by bountyhunter
Replied by bountyhunter on topic help with some jets
If you have the stock airbox on it and the pipes have a street baffle in place, I would guess you would likely need to only go up maybe one jet size on the main and pilot above the stock jets. That's just a guess.
For needle, start with stock and see how your low end throttle response feels.
Last edit: 31 Aug 2009 11:59 by bountyhunter.
