Which carbs to use for a GPZ1100 swap
- jcote75
31 Aug 2009 10:21 #317897
by jcote75
Which carbs to use for a GPZ1100 swap was created by jcote75
Will be installing carbs on the GPZ1100B1.
I heard that KZ750R1 carbs are the same has a kz1000J which are Mikuni BS34.
I got in hand a set of a KZ750R1 (1982 GPZ750) and a set from a 1983 GPZ750 Unitrack.
both look quite the same, which one to use???
Tks
Tks
- Z1109R Fin
- Thank you received: 1
01 Sep 2009 01:15 #318153
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Which carbs to use for a GPZ1100 swap
They might just be tha same Mik BS34´s but the spacing of throat mey be differnt as 750 is much smaller engine.
According to Sudco RS34 listing it is the same but make shure first.
