Mikuni RS34 KZ1100
- KZ1100 Bully
29 Aug 2009 05:43 #317249
by KZ1100 Bully
1983 Kawasaki KZ1100 Spectre D2
Mikuni RS34 KZ1100 was created by KZ1100 Bully
Hi, I want to upgrade my carbs to a set of Mikuni RS34. Do you think they will work well on a stock motor? Going to also buy a kerker 4 to 1 comp baffle. I want to also install a 1075 kit but not for a few years.
Would those carbs be a good choice? It is a street bike.
Thanks
Thanks
- Old Man Rock
- Thank you received: 225
29 Aug 2009 05:59 - 29 Aug 2009 06:01 #317257
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Mikuni RS34 KZ1100
As old Buzz at Dynoman as well as some others here informed me....
RS34, great carbs for RACING..... If you plan on riding at WOT all the time, beautiful carb, otherwise would be a waste...
900-1075cc motor with performance camshafts, head P&P, Kerker w/1.5" comp baffle... Preferably/ideally 29mm, 31mm max for an enjoyable and powerful street ride...
If your looking for more excitement out of your motor... 1075 kit and performance cams with the Kerker will be more than enough.
BTW, what carbs do you presently have installed?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 29 Aug 2009 06:01 by Old Man Rock.
- KZ1100 Bully
29 Aug 2009 07:15 - 29 Aug 2009 07:15 #317287
by KZ1100 Bully
Replied by KZ1100 Bully on topic Mikuni RS34 KZ1100
Bike has stock carbs, not sure what they are?
Last edit: 29 Aug 2009 07:15 by KZ1100 Bully.
- Buda
29 Aug 2009 07:33 #317293
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Replied by Buda on topic Mikuni RS34 KZ1100
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
- kzr750r1
- Thank you received: 9
29 Aug 2009 08:13 - 29 Aug 2009 08:17 #317295
by kzr750r1
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
Replied by kzr750r1 on topic Mikuni RS34 KZ1100
RS are just that. Great carbs for WFO. Hard to use in town and normal street riding, IMO. All depends on your goals.
I have recently gone back to the BS34 from the RS34 to attain a better drivability. Granted your bike may be ok as you have the displacement. But there are other options out there...
Keihin make some nice carbs as well. Note the throttle valve having a different guide than the RS. The RS are always going to clatter at idle. Wonder if the FCR are a bit more tame on the street? Or if they are even available any longer for the KZ/ZR horizontal configuration these days.
Until (if ever) I upgrade to an 810 and bigger cams there was really no need for them on the 750. My ability to lean out the motor with to much throttle opening was a problem mid turn. Steady and easy wrist would pay back in spades though. Motor would go through the rev range in a hurry.
As always there are many options. Including rejeting the stock carbs.
Last edit: 29 Aug 2009 08:17 by kzr750r1.
- KZ1100 Bully
29 Aug 2009 09:00 #317303
by KZ1100 Bully
yes buda they look like those you uploaded. I just want to get better throttle response, better carbs seems like a good place to start.
- kzr750r1
29 Aug 2009 10:24 #317321
by kzr750r1
The BS should do you justice. Make sure they are working correct though. I cheated and sent mine to WG. Now it's on me for tuning and it's getting there... Many years ago made the mistake of allowing a dynajet stage 2 kit go in. Fighting this kit a bit it seems. Much more comfortable a street setup than the RS. RS just wanted to GO GO GO all the time. Survey is out still but I think the bike is getting better fuel mileage with the BS as well.
There are some limited parts available for BS. Diaphragms can cost $400 to replace all with clean OEM parts. If you can find them.
If course all depends on the condition of yours how much restoration cost would be.
The full on restoration price range would take me looking elsewhere also.
Good luck in the quest.
- Buda
29 Aug 2009 10:30 - 29 Aug 2009 10:32 #317326
by Buda
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
As far as the diaphrams go iv bought a couple of sets of bs34s from ebay (less than $100 each) and have extra sets of diaphrams as well as spare parts.
Your bs 34s can give you what your looking for with a little work. Mine run great now but it took a little doing.
Tom
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Last edit: 29 Aug 2009 10:32 by Buda. Reason: more info
- KZ1100 Bully
29 Aug 2009 11:39 #317341
by KZ1100 Bully
Thanks guys, the bike runs great. Carbs are very clean. I just thought I could get a better set. I was looking for the wow factor as well. Just wanted some new high end parts on the bike.
- Z1109R Fin
- Thank you received: 1
31 Aug 2009 03:25 #317796
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Mikuni RS34 KZ1100
Manual flat-slides like RS34´s are better in way of throttle response and raw power. So it depends on what you´re looking for. Commuting and cruising go with BS34, riding twisties and maybe occasionally on track then definately RS34´s.
I´d never go back to CV -type carbs! I just love the raw response and power of my TM33´s
