- Thank you received: 4
Temporary Gas Supply Question
- freebyrd24
28 Aug 2009 11:54 #317036
by freebyrd24
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
Temporary Gas Supply Question was created by freebyrd24
Hey everyone I am looking to crank up my bike and make sure it is in good running order while my tank still needs to be cleaned thoroughly internally and painted externally. When hooking up an external tank without a petcock, what do I need to do? My carbs have a vacuumm line that I do not know what to do with and obviously i have the main fuel line. Do I need to block off the vacuumm line? Is fuel just going to rush into the carbs like it is on the PRI position? I guess I'm unsure of vacuumm anything that could prevent me from getting fuel properly to the carbs.
I want to know how it is done so I don't try to clean the carbs 100 times and think its a carb issue.
Thank you!
Thank you!
Sold:
- mzandmz
28 Aug 2009 12:11 #317039
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Temporary Gas Supply Question
Make sure you put a NEW fuel filter on your temparary contraption. No need to polute your fresh rebuilt carbs.
- MFolks
- Thank you received: 540
28 Aug 2009 12:47 #317048
by MFolks
Replied by MFolks on topic Temporary Gas Supply Question
A wooden golf tee makes for a good temporary plug for a gas or vacuum line.
- freebyrd24
28 Aug 2009 12:55 #317052
by freebyrd24
Sold:
Replied by freebyrd24 on topic Temporary Gas Supply Question
Ahhh I never even thought of a golf tee. Good idea! Do I have to block off the vacuumm line to carbs then?
Sold:
- fixer5000
28 Aug 2009 13:15 #317058
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic Temporary Gas Supply Question
absolutely yes!!
massachusetts
- freebyrd24
28 Aug 2009 13:28 #317062
by freebyrd24
Sold:
Excellent thank you! I just wanted to rule that out, I have to go back and check float heights. I suspect that's my issue!
Sold:
