The ultimate n00b question... Draining fuel tank?
- The_Raven
27 Aug 2009 21:22 #316895
by The_Raven
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
The ultimate n00b question... Draining fuel tank? was created by The_Raven
Howyadoin,
I need to replace my petcock due to a slow leak, so I need to drain my fuel tank first. I'm figuring to pull the fuel line downstream of the petcock with the petcock set to ON or RES, then run the line to a funnel into a gas can. Then set the petcock to prime (bypassing the diaphragm) and it should drain no problem, right?
Does this make sense as a method or am I doomed to perish in a big fireball 'o stupidity and hi-test?
Thanks
Thanks
-Mark P.
Salem, MA
- MFolks
- Thank you received: 540
27 Aug 2009 21:26 #316897
by MFolks
Replied by MFolks on topic The ultimate n00b question... Draining fuel tank?
Should work well,just do it in a well ventilated area with no sparks or flames.
- Kawickrice
- Thank you received: 18
27 Aug 2009 21:30 #316898
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic The ultimate n00b question... Draining fuel tank?
Sounds like a good plan to me. I just run most of the fuel out then when the tank is removed I prop the back up and leave the fuel in it. As long as it does not drip from the cap you will be alright. If you are gonna clean the tank then its best to drain all the fuel
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- PLUMMEN
- Thank you received: 104
27 Aug 2009 21:36 #316902
by PLUMMEN
Replied by PLUMMEN on topic The ultimate n00b question... Draining fuel tank?
id say just drain it into the lawn mower tank since your emptying out your tank your probably gonna get some crud out of the bottem that ya dont want to dump back into your bike,lawn mowers are much more forgiving creatures! :laugh: while its apart maybe dump some acetone in the tank and shake it around really good to clean it out really good before reinstalling your rebuilt petcock
- The_Raven
04 Sep 2009 19:43 #319151
by The_Raven
-Mark P.
Salem, MA
Replied by The_Raven on topic The ultimate n00b question... Draining fuel tank?
Just to follow up for anyone who might find this in a search, this method worked fine. Also, it seemed that when I opened the gas filler cap, the fuel flowed faster, just to speed up the process for ya...
-Mark P.
Salem, MA
- Thank you received: 2237
04 Sep 2009 20:35 #319160
by TexasKZ
Replied by TexasKZ on topic The ultimate n00b question... Draining fuel tank?
And before installing a quality fuel filter.
