still have got some issues after jetting
- Darkangel
_________________________________________
1983 Kawasaki KZ 1100 A2 - streetfighter
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Darkangel
- roy-b-boy-b
- Thank you received: 103
- Old Man Rock
- Thank you received: 225
"I still have some poping going on"...
Where exactly is this occurring?
Meaning at idle runs erratic and pops, when running in low to mid range pr when accelerating it pops or more specifically when releasing the throttle and when it snaps back it pops.... Pops out carbs or exhaust during these operations....
At idle, is it popping out the carbs especially cylinder 1?
As Roy mentioned, for idle turn your air screws for more rich operations.
Also, are you still running this exhaust without a baffle? :blink:
And of course, sync the damn carbs already will ya...
We have to rename Dark here "Dark Lord of the Jetting"... :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
- Thank you received: 20
I'd do the following:
1) if you for whatever reason had to install a new larger main jet to get the 'extra power' (for example, maybe you installed a 4-into-1 pipe, and/or replaced the stock air box with individual 'pod-style' filters on each carb) -- if you installed a new larger main jet to get that extra power -- you need to adjust the needle clip to raise the needle a notch and you also need to install a larger pilot jet.
2) CHECK THE TIMING. If you have points, check for pitting of the points, check for correct gap on the points (I believe the gap is 3-4mm, but check that in the manual). After you check the points gap, using a timing light (decent t. light can be had at Kragen for $40) and the timing marks on the ignition end of the motor make sure the timing of the points opening is correct. NEED A SHOP MANUAL to do it right.
3) Check your spark plugs. Is the gap correct? Check the spec for the plug gap in the manual. Are the plugs old? THEY'RE CHEAP, buy a new set of 4 for $12.
But if you needed to go to larger main jets, you need to look at the needle clip and pilot as above.
Good luck, sounds like you're really close!
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
- Darkangel
10 minutes of running... You're no longer cold!
OMR
Ok here's the whole run down...
When i take off and I am running in the mid range it will pop, and it's coming off of 2,3, but they all pop at some point in time..when i take the throttle off, and right back on.. I am still running strait headers for now...no baffle. I am getting an exhaust headers that I can retrofit to a sports exhuast from MAC in the winter.And yes i need to still sync. I am going to do the needles and jets in the winter..
- roy-b-boy-b
Do you need a Mac header? I have the header part but not the baffle end. I'll give you a good deal. Roy
- Darkangel
But I am running 140's and I should be running a 52.5 needle jet, but I am not...Granted this is from running 120 mains.
- Darkangel
- Buda
You have electronic ignition, no points.I want to make sure that I have the carbs just right before I take the engine out of the frame to put top end gaskets on it, port the heads, and put knew points on it...Or what do you guys think about that...?
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- Darkangel
