csr1000 misfire
- kwak650
27 Aug 2009 14:31 #316790
by kwak650
csr1000 misfire was created by kwak650
I got a 1981 csr1000 running 4 into 1 exhaust,k&n pod filters with stock jets.When I start the bike after it sat for a couple of hours it always mifires.I pull off the plug cap let it arc for a second and that cyclinder fires up.It moves around different cyclinders.The bike runs good after that but I have noticed it runs a bit rich. Any help would be great.
- Kawickrice
- Thank you received: 18
27 Aug 2009 17:09 #316816
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic csr1000 misfire
Does it go away when it warms up? Could it be that it is still cold and still running on the chock?
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- kwak650
28 Aug 2009 13:55 #317070
by kwak650
Replied by kwak650 on topic csr1000 misfire
It will not go away unless I pull off the plug cap for a couple of seconds and let the spark jump the gap or swap out the plug.I am after tring all different brands of plugs but it doesent make a difference.It doesent matter if the choke is on or not.
- keith1
- Thank you received: 2
28 Aug 2009 17:38 - 28 Aug 2009 17:39 #317143
by keith1
Replied by keith1 on topic csr1000 misfire
pods and a pipe with stock jetting and its running rich?
you definitely need to scope out ignition system.....good battery,good coils, wires good, plugs not old and done?
Last edit: 28 Aug 2009 17:39 by keith1. Reason: grammar
- kwak650
29 Aug 2009 06:50 #317279
by kwak650
I know the battery and charging system are good,I installed a rotor from electrosport works great.Whats the best way to check the coils,ignition box and pick up coils.
- tinlizzie37
29 Aug 2009 07:03 #317286
by tinlizzie37
Bob KZ 650 E1, En 450
Replied by tinlizzie37 on topic csr1000 misfire
With pod air cleaners, you need to increase the pilot jet size by at least one size. Might want to increase the main also. It is running lean and popping and missing. This probably will fix your problem. Anyone agree?
- kwak650
29 Aug 2009 09:10 #317304
by kwak650
The bike runs fine once it get going,pulled all plugs a number of times and they are all fouled black.There is no backfire or popping when riding,there is a bit on start up but usually clears up.
