Slow speeds not smooth 1981 KZ 440
- tygoebel
27 Aug 2009 14:09 #316784
by tygoebel
Slow speeds not smooth 1981 KZ 440 was created by tygoebel
I have recently cleanned the carbs on this bike. It wasn't running before the carb cleaning. It starts easy and runs good except for low speeds. Trying to maintain a constant speed of 30 mph or less (1/4 throttle or less) it sounds like I am popping corn.
Acceleration is good (no backfiring) and higher speeds are good.
Does this sound like the pilot system is still in need of attention. Pilot screw are turned out 1 1/2 turns.
Thanks in advance
Thanks in advance
- mzandmz
27 Aug 2009 14:15 #316786
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Slow speeds not smooth 1981 KZ 440
Hows the sycronization of the carbs?
- tygoebel
27 Aug 2009 14:35 - 27 Aug 2009 15:47 #316791
by tygoebel
Replied by tygoebel on topic Slow speeds not smooth 1981 KZ 440
I did try to sync the carbs using a home made thing. (A 10 foot clear tube wrapped around a yard stick with oil in the tube and makeing sure that both carbs were pulling the same vaccum. Found this method on the net)
Short answer - I think the carbs are synced
Last edit: 27 Aug 2009 15:47 by tygoebel.
- Link14
- Thank you received: 6
27 Aug 2009 15:41 #316800
by Link14
Replied by Link14 on topic Slow speeds not smooth 1981 KZ 440
With my kz400, getting the carbs synched did a world of good. Also, I found that if I didn't pull the pilot screws when I cleaned the carbs, I couldn't really get those passages blown out with air after I hit them with carb cleaner.
