- Thank you received: 20
burning thru a 'hasn't run in 12 years' checklist!
- newOld_kz1000
- FlimFlamFlibbityFlee !! BoonFryedShickaMuhZee !!
25 Aug 2009 20:38 #316410
by newOld_kz1000
1978 kz1000 A2 with Kerker
1980 Z1 Classic with Kerker
burning thru a 'hasn't run in 12 years' checklist! was created by newOld_kz1000
Okay, I've nearly cleaned the carbs and ! am proceeding with "hain't been run in 12 year"
process to revive my kz1000 1978 that hasn't run in oh say 12 year.
And here is my checklist, I'm about to run through it now:
1) finish cleaning carb bodies (nearly done)
2) use a guitar string to clean the jet holes
3) lubricate the throttle slides with some light oil (they were sticking a bit)
4) install the new jets
5) set the proper float height
6) adjust the carb's air screws as per the manual
7) before putting the carbs back on, remove the spark plugs and spray some lubricant into the cylinders -- they've been dry a long time
re-install the carbs
9) install and adjust the throttle cables
10) trickle charge the new battery if it doesn't read 12 volts
11) install the battery, check for spark on all 4 plugs
12) check the timing using the timing lite with the motor off (if possible) or use the timing marks
13) if the timing is good and there is spark, flush the gas tank and clean the petcock and change the engine oil and oil filter
14) gap and install the 4 new spark plugs
15) put new fresh gas in the tank
16) kick it over and see if it will start
WHAT IF ANY AM I MISSING HERE?
- MFolks
- Thank you received: 540
25 Aug 2009 20:46 #316413
by MFolks
Replied by MFolks on topic burning thru a 'hasn't run in 12 years' checklist!
If the battry is fully charged, you should read the same amount at the ignition coils.
If down around 8-10 volts when measured at the primary(small wires) side of the coils go to www.wgcarbs.com and read up on doing the ignition coil bypass in the wiring using a relay and simple wiring modification.
New sparkplug caps will ensure the spark is being transmitted to the plugs along with new plug wires.
- 550A2
- keep the shiny side up
- Thank you received: 1
25 Aug 2009 21:12 #316439
by 550A2
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Replied by 550A2 on topic burning thru a 'hasn't run in 12 years' checklist!
that looks like a winner to me man, all else i could add is put air in the tires and lube the chain, lube all the cables, (clutch-throttles) maybe tach cable.
thats more for driveability, but once you get er runnin you are gonna wanna ride it, i know i would... so might as well get it all.
let us know how it goes dude!
good luck!
Luke
good luck!
Luke
- donthekawguy
- Thank you received: 8
25 Aug 2009 23:01 #316448
by donthekawguy
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
Replied by donthekawguy on topic burning thru a 'hasn't run in 12 years' checklist!
Thats a lot more than I would have done. :laugh: I'm a change the oil, put in new gas and go kinda guy.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- Thank you received: 2829
26 Aug 2009 07:57 #316509
by 650ed
Replied by 650ed on topic burning thru a 'hasn't run in 12 years' checklist!
Be sure to change the oil before you hit the starter. Also, to make sure you don't need to pull the carbs again, I would install a quality fuel filter in case there's bad karma hidden in the tank or petcock and carefully check the carb holders for signs of cracks and replace now if in doubt. Ed
- trianglelaguna
- Thank you received: 235
26 Aug 2009 08:34 #316518
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic burning thru a 'hasn't run in 12 years' checklist!
checklist for me too.....
donthekawguy wrote:
1976 KZ900
2003 ZX12R
2007 FZ1000
- PLUMMEN
- Thank you received: 104
26 Aug 2009 09:23 #316525
by PLUMMEN
Replied by PLUMMEN on topic burning thru a 'hasn't run in 12 years' checklist!
if its been sitting 12 years id also pitch the tires,flush the old fluid out of brakes and give it a good going over from one end to other.lots of things get dry rotted and forgotten over a 1 year period,let alone 12! :laugh:
- Locozuna
26 Aug 2009 09:28 #316526
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic burning thru a 'hasn't run in 12 years' checklist!
Clean the petcock screen and bowl. Put inline fuel filters in. Air filter inspection. Remember to get ready to hit the kill switch in case she goes rogue. Try not to let your smile hit you in the back of the head if she fires up!
Then check your cables, tires, chain and sprockets. Your brakes and hoses.
Your swingarm and front bearings.
Electricals should be cleaned and di-electric greased.
You can skimp and hurry but do not do that on things that can kill ya in the blink of an eye. Sometimes there is no time to hit the do-over button.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- newOld_kz1000
27 Aug 2009 19:46 - 27 Aug 2009 19:54 #316871
by newOld_kz1000
Replied by newOld_kz1000 on topic burning thru a 'hasn't run in 12 years' checklist!
Yep, that's why I like to post it, I left out some things and you guys pointed them out.
- My plan with the gas tank was in fact to drain the gas in there now and pull and clean the petcock. Didn't mention it but essential -- you guys wouldn't believe how bad the float bowls and jets were! Black with thick tar resin.
- And it's weird -- the gas in the tank only has a barely noticeable scent of varnish, so as one of you mentioned he put something in there like stabilizer in the tank
- the oil change -- forgot all about it. Thanks for the reminder!
- the electrical cleanup -- thanks for that tip.
- both front and rear brake levers are froze stuck (calipers are 'okay' in that wheels turn freely)
and I'm putting off that job until it's running okay.
Good call about the brake job, I'll be back to ask for help on that, never done a 12-year-sitting master cylinder rebuild! I don't even know if they're salvageable.
- tires look okay but I will replace them before any higher speed riding. Will keep them on to sort it out riding around the house at 25-30 mph.
Just some *excellent* advice from you folks, thanks!
Last edit: 27 Aug 2009 19:54 by newOld_kz1000. Reason: added content
