- Thank you received: 1
VM24 - Float Bowl Screws
- HerrDeacon
They list the following:
Is there a way of determining which one based on the current ones I have? What is the first digit and second digit actually refer to. Is it just width and length?
Thanks
- fixer5000
- Thank you received: 5
1978 kz650b pretty much stock
massachusetts
- Bluemeanie
- Thank you received: 14
- HerrDeacon
Even tried the parts diagrams on Bike Bandit, but they don't list the screw dimensions.
I'll do some measuring, like fixer suggested, when I get home tonight.
Thanks guys.
- RonKZ650
- Thank you received: 240
- JR
- Thank you received: 449
if you have a good Canadian Tire store near you then you can get the stainless steel Allen Screws. They should have them in the little drawers. Thats what I did.
- KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- HerrDeacon
Just went up to CT on my lunch but they never had anything. Really sparse on anything metric related. I believe Kent may have some though so I'll check them out for the allen head, as they would be great to have over the phillips.
- JMKZHI
- Thank you received: 48
The Babbitts Online diagrams are better than most. They seem to be fairly identical to the Kaw diagrams from a few years ago and include the full part number & other info, such as brake line length & bolt size.Just checked Kawasaki they just list the whole carb assembly, not individual parts. This must be something new as I'm sure I looked at the breakdown last year.
RonKZ650 wrote:
They are 4x16
- HerrDeacon
- Thank you received: 2829
