Cracked overflow tube...
- chrispysaki
It also looks like this might have been an issue for the previous owner, since there's some type of putty where the tube connects to the float bowl body.
Any suggestions? I'm thinking about using some type of epoxy to seal up the crack. Maybe silicone caulk??? Maybe a two-part epoxy. I have no idea what to do if that won't work.
- Thank you received: 2829
- Thank you received: 2098
Two of the carbs in my 1980 kz750 were leaking gas through the overflow tubes. I took apart the float bowls to free up the float needle, but it looks like the gas is actually escaping through a crack in each of the brass overflow tubes inside the float bowls. I checked the two that weren't leaking and neither had a crack.
Crack in tube itself might be sealed with solder, or JB Weld, or snug fit thin wall plastic hose over the tube, or heat shrink-fit tubing.
Crack or break where tube joins carb body -- best repair choice may be JB Weld, or possibly solder.
When repair is completed, before reassembling float bowl to carb, would test for flow through the tube. And assure it's not clogged with JB Weld or solder.
Could also do a search for similar threads by typing something such as "cracked overflow tube" in the search box toward top of screen on the right hand side. Probably find additional (maybe better) repair suggestions.
Good Luck!
- chrispysaki
- hardr0ck68
- Who put the what in the where?
- Thank you received: 3
I have a set of vm24's with acel pump that are junk, but the float bowls are still good... does anyone know if they will swap out?
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- chrispysaki
- JR
- Thank you received: 449
It you use JB Weld make sure you let it cure for at least 24 hours before coming into contact with gas.
- chrispysaki
That brass tube is a great idea...I thought about just soldering the existing tube, but I was worried about melting it.
I took the bike out for about 1/2 hour yesterday and so far, so good. (except now that I've finally gotten to run it more than around the block, I noticed the oil leak around the header is worse than I realized - anyone know if tightening the header bolts is a 'good enough' solution for the rest of the summer?)
