Float adjustment process
- Nats82
16 Aug 2009 06:37 #314286
by Nats82
Float adjustment process was created by Nats82
The bike is an 82 550ltd. I thought I kind of understood the steps for float adjusting, But.....was ready to try and got alittle confused. The carbs are off the bike, I understand that they must be level. I'm just not sure of the drain orfice, must they be plugged to keep the gas from leaking out of the bowls while testing? I guess what I'm asking is, is there some one that could explain the process, ie... clear tube makings, where the gas line should be in relation ship to the carb bowl. Should the idle knob be set a certain way..on and on and on, sorry for being kinda lost here. Any help would be absolutley great!!
- Thank you received: 2829
16 Aug 2009 06:43 - 16 Aug 2009 06:45 #314287
by 650ed
Replied by 650ed on topic Float adjustment process
Take a look at this posting, it may help. Also, you should pick up a Kawasaki Factory service manual for your bike. They can be found pretty cheap on ebay and they are worth their weight in gold. Be sure to get the correct one for your specific model/year. Ed
link
link
Last edit: 16 Aug 2009 06:45 by 650ed.
- mzandmz
17 Aug 2009 08:42 #314573
by mzandmz
New to Family, 1979 KZ440 LTD
Replied by mzandmz on topic Float adjustment process
Yes a factory service manuel would be nice to have.
