vacuum ports on int manifold???
- tigertile
14 Aug 2009 18:41 #313977
by tigertile
vacuum ports on int manifold??? was created by tigertile
i just put carbs on a kz1000 what are the vacuum ports on the manifolds for????
- MFolks
- Thank you received: 540
14 Aug 2009 19:02 #313984
by MFolks
Replied by MFolks on topic vacuum ports on int manifold???
For the carb sync adjustments. This is how with a running engine the carbs are adjusted to equalize the air flow.
First thing to do is check the valve clearances before any tweaking of the carbs. If a valve is on the "tight" side of the clearance,heat from running may have a valve leak compression screwing up trying to sync the carbs.
- tigertile
14 Aug 2009 19:25 #313990
by tigertile
Replied by tigertile on topic vacuum ports on int manifold???
thanks mfolks
