carb hoses
- ohioKZnut
13 Aug 2009 14:47 #313729
by ohioKZnut
78 KZ 650
carb hoses was created by ohioKZnut
Can someone tell me what the hoses hanging off the carbs are for?And would it hut if a couple are melted shut.thank you
78 KZ 650
- MFolks
- Thank you received: 540
13 Aug 2009 15:06 #313732
by MFolks
Replied by MFolks on topic carb hoses
Can you take a picture? Some carb hoses are supply lines, others are float bowl vents, and some act as pressure vents when the fuel comes from the tank.
If you tank has a vacuum petcock(fuel valve) it needs a line from at least one carb to let fuel flow through a diaphram.
- Thank you received: 2098
13 Aug 2009 15:16 #313735
by Patton
Replied by Patton on topic carb hoses
ohioKZnut wrote:
I suspect this refers to the hoses attached to bottoms of float bowls which are the overflow drains.
These hoses are usually routed past the swingarm to exit underneath the bike.
The ends may be clipped off to open them back up.
Important for them to be clear so that the carb overflow circuit may properly function.
Good Luck!
[Click on image to enhance view]
Good Luck!
13 Aug 2009 15:23 - 13 Aug 2009 15:37 #313737
by Patton
This particular example has four manual slide carbs. Other type carbs are CV or vacuum operated carbs, identifiable by the large round tops on each carb.
This example has a separate nipple for a hose to a vacuum operated petcock, and also has an accelerator pump.
Some carbs have one or the other or neither.
Also, this example has a single fuel line, whereas some carbs have dual fuel lines.
Good Luck!
Good Luck!
Last edit: 13 Aug 2009 15:37 by Patton.
13 Aug 2009 15:41 - 13 Aug 2009 15:42 #313740
by Patton
Here's a diagram of the oem 1978 KZ650B manual slide carb from kawasaki.com.
Good Luck!
Good Luck!
Last edit: 13 Aug 2009 15:42 by Patton.
