High idle after warmup
- Summerheat
- Wanted at 17 Got it at 47 Worth The Wait!
12 Aug 2009 06:03 #313331
by Summerheat
1976 KZ900-A4
High idle after warmup was created by Summerheat
Got my KZ-Gal back together after a valve/shim job and carb rebuild.
Sync process went well getting all 4 dialed in around 23, and she runs through low/mid range & high power bands wonderfully. (actually pulls better then she ever has)
She starts better then ever and plugs look a wonderful white/tan. I have new vacuum caps on her and new carb holders
When cold her idle is perfect. Once up to operating temps idle climbs to 2000 with idle screw backed off all the way. The throttle pulley is all the way against return stop. Idle/air is 1 3/4 out from slight seat.
Any and all suggestions appreciated for this fast idle.
Thanks
Thanks
1976 KZ900-A4
- bill_wilcox100
- Thank you received: 5
12 Aug 2009 06:23 #313335
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic High idle after warmup
Hi Summerheat,
Here are two possibilities that come to mind:
-1) Air leak... at carb Holders, at Vacuum Caps, in Vacuum line to Petcock...
-2) One or more carb slides was set just a little too high during carb sync, is OK during Choke operation but is open just a little too much when hot.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
- Russ Jackson
- Thank you received: 1
12 Aug 2009 07:10 #313345
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic High idle after warmup
What kind of carbs? My smoothbores will not idle below about 1800 with the Kerker and jetting set up I have...Russ
- Summerheat
12 Aug 2009 07:12 - 12 Aug 2009 07:13 #313347
by Summerheat
1976 KZ900-A4
Replied by Summerheat on topic High idle after warmup
vm26's / Kerker meg with 2.0 baffle & pods / 120 mains and rest of carb internals stock.
Had normal idle before work and new parts. Looks like I will be testing for air leaks and getting my Morgan Carbtune back out.
1976 KZ900-A4
Last edit: 12 Aug 2009 07:13 by Summerheat.
- Old Man Rock
- Thank you received: 225
12 Aug 2009 07:14 - 12 Aug 2009 07:16 #313349
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic High idle after warmup
With that set up, almost guaranteed new jets will be required... Assuming you haven't already done so....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Aug 2009 07:16 by Old Man Rock.
- Summerheat
12 Aug 2009 07:16 #313351
by Summerheat
1976 KZ900-A4
OMR, I edited as I forgot to mention main jet change.... Are you thinking something else needed?
1976 KZ900-A4
- Summerheat
12 Aug 2009 10:15 #313379
by Summerheat
1976 KZ900-A4
More info... been thinking ( yeap it's dangerous)
I bench synced these carbs with the wire method. Now if I did not have idle screw turned in any during this process would it cause my inability to lower idol? Or would my manometer sync take care of this.
or stated another way
Should I have had idol screw in enough to open carbs before closing down to wire thickness?
1976 KZ900-A4
- bill_wilcox100
12 Aug 2009 11:26 - 12 Aug 2009 11:29 #313391
by bill_wilcox100
Upgrades:
Montreal, Canada
IMHO, that's exactly the type of question that should be asked at this point... good stuff!
Remember, the nano/gauge sync only gets the slides properly adjusted with respect to each other... right. Then each one is sucking in by the same amount.
Again IMHO, in other words, it prevents any one carb (and therefore its corresponding cylinder) from not pulling enough or pulling too much. This in turn puts less stress/imbalance on any one section of the crank shaft preventing harmful harmonics (stresses) being built up.
That's what makes a really well Sync’d engine feel soooooo smooth.
Best of success.
Bill
Best of success.
Bill
Upgrades:
Montreal, Canada
Last edit: 12 Aug 2009 11:29 by bill_wilcox100.
