Airbox missing parts.. Weird filter replacment...
- byten
11 Aug 2009 12:14 #313171
by byten
Airbox missing parts.. Weird filter replacment... was created by byten
I just inherited a KX750-N1 Spectre. The air box is missing the air filter and associated parts. In place of the filter is some sort of plastic lid that fits the air box. There is a central hole cut in the lid with a radius of approximately 1/4 the diameter of the lid. Astonishing, the bike runs. It idles semi-smoothly at about 1400 rpm, but gets pretty ruff at 1100 rpm. I have searched for replacement parts, but the dealer can't get them and I can't find them on eBay. What would you recommend I do? Pods? Has anyone here ever heard of using this punched out lid solution? I’m thinking lean…..
- ccvt98
11 Aug 2009 14:55 #313189
by ccvt98
1980 KZ750H1 LTD *restored*Feb '09
1982 KZ1100A2 Shaft *in process of resto*
1982 KZ750 Almost Completed
2001 Honda XR100 "son's"
2010 Kaw Z1000
Replied by ccvt98 on topic Airbox missing parts.. Weird filter replacment...
i have a complete air box with the rubbers and filter that came off my 80 kz750h1 ltd,don't know if it would fit ,but if so, give you a deal on it.
2010 Kaw Z1000
- JMKZHI
- Thank you received: 48
11 Aug 2009 16:25 #313202
by JMKZHI
Replied by JMKZHI on topic Airbox missing parts.. Weird filter replacment...
You can probably use an airbox from an 80-83 KZ750-Ltd-4, 80-82 KZ750-E Standard or 81-83 KZ650-CSR, among others. The cross-reference at Kawasaki.com will show that some bikes use the exact same airbox, but the airboxes from the bikes mentioned would be more readily available & will only have minor differences.
- byten
11 Aug 2009 18:46 #313238
by byten
Replied by byten on topic Airbox missing parts.. Weird filter replacment...
Thanks for the info. I'll look into it. I have the airbox, I just don't have any of the parts to mount the filter. I'm going to check some salvage yards this weekend. I still find it strange that it runs so well with that lid.
