1975 KZ 440 Carb Boots
- That_DJ_Guy
All parts are for a 1975 KZ 440:
carb boots (front and back)
Front right turn signal
Tachometer cable
Speedometer cable
clutch cable
throttle cables (both top and bottom)
front brake hose (from reservoir to adapter where it goes into a regular line
turn signal/horn/hi low beam switch assembly
stock left mirror (or set similar to original that will fit)
Side cover KZ440 emblems (both left and right emblems)
I know many of these parts are no longer available, but if someone can point me in the right direction (ie: cross referenced parts that will work), I will gladly send paypal money to those who help me.
This bike means the world to me, and I would like to get it ready for the 2010 riding season.
Thanks everyone for your time!
Jack Millz
info@jackmillz.com
- That_DJ_Guy
- That_DJ_Guy
- Thank you received: 2098
Click here and scroll through the pages > KZ440 at Z1 Enterprises
Good Luck!
- MFolks
- Thank you received: 540
- That_DJ_Guy
- Nebr_Rex
- Thank you received: 300
( front right turn signal,tachometer cable,speedometer cable,clutch cable,throttle cables,front brake hose )---Parts Unlimited
turn signal/horn/hi low beam switch assembly--- Z1E
stock left mirror--- Parts Unlimited
Side cover KZ440 emblems--- factory (e-bay)
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- loudhvx
- Thank you received: 1616
I just found out my bike is a 1975 kz 400-d, even thou my title says my bike is a 440...
Better check the vin, just to make sure. Your bike, from the photos, is a 400. There wasn't a 440 in 1975 as far as i know.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- That_DJ_Guy
- That_DJ_Guy
- That_DJ_Guy
www.oldbikebarn.com/Kawasaki-KZ400-Side-...sc=12&category=74691
almost identical side cover emblems
