jet size?
- asevans
08 Aug 2009 18:49 #312510
by asevans
1976 kz900 Mostly stock
1978 Z1-R Project
jet size? was created by asevans
kz900, air pods, vance and hines 4 into 1. what size jets do i need. thanx
1978 Z1-R Project
- asevans
08 Aug 2009 18:50 #312512
by asevans
1978 Z1-R Project
Replied by asevans on topic jet size?
with the baffle left in. thanx
1978 Z1-R Project
- Thank you received: 2098
08 Aug 2009 19:15 - 08 Aug 2009 19:22 #312519
by Patton
Replied by Patton on topic jet size?
Original KZ900 carb jets may be okay with existing set-up.
Would rely on plug readings after high speed throttle chop (simultaneosly cut ignition and disengage clutch), to indicate whether any main jet changes should be considered.
Shows what's actually going on inside combustion chambers at wot where main jets are ruling the roost.
Remember the story where all the experts were researching and debating about how many teeth are in a horse's mouth. Until somebody just opened a horse's mouth and counted the teeth. The plug reading is like counting the teeth instead of just prognosticating about the number.
Good Luck!
Good Luck!
Last edit: 08 Aug 2009 19:22 by Patton.
