jet setting for pods or stay with stock box?
05 Aug 2009 13:56 #311797 by tugmonkey77
I have a stock (just finished re-building) 1978 KZ 650D SR. I was given K&N pods but don't know what the carb settings should be. Right now stock is 120 main, 25 pilot and 0.9 air. what should they be for pods and where can i get new jets... if needed? on the other hand what are the pros to pods other than the obvious easier on/off of carbs. Show me the true path fella's.
05 Aug 2009 14:05 #311800 by bountyhunter
Replied by bountyhunter on topic jet setting for pods or stay with stock box?
I don't think pods have any advantage other than easy removal. Maybe they allow more airflow but the carb needles are designed for a specific flow characteristic so the pods won't match it. I think if you are racing and want a little more power over a narrow RPM range, pods will do that. If it's a street bike and you want good rideability over the full RPM range, the airbox is the way to go.
05 Aug 2009 14:37 #311815 by Patton
I was given K&N pods...what are the pros to pods?...Show me the true path fella's.
Click here > The True Path?
Good Luck! :)
05 Aug 2009 16:28 #311832 by 650ed
Short answer: if you like riding stick with the airbox; if you like spending hours tinkering in the garage trying to find the elusive magic combination that works well for pods on your bike (or if you're feeling lucky)go with pods.
Short question: What's broke that you're trying to fix? (because if it ain't broke ......) :)
06 Aug 2009 18:50 #312093 by will61310
Replied by will61310 on topic jet setting for pods or stay with stock box?
oooh boy, here we go again! :ohmy:
...1980 LTD 1000...
06 Aug 2009 18:57 #312095 by Locozuna
Replied by Locozuna on topic jet setting for pods or stay with stock box?
:pinch: :pinch: :pinch: :whistle:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
06 Aug 2009 21:24 #312132 by mzandmz
Replied by mzandmz on topic jet setting for pods or stay with stock box?
P.O.D = Piece Of Dung
New to Family, 1979 KZ440 LTD
07 Aug 2009 07:18 #312179 by will61310
The pod haters awaken.....:dry:
...1980 LTD 1000...
07 Aug 2009 10:15 #312218 by Locozuna
I don't think so peewee.
Anybody got a question about it do a search. All the info is there for both sides. Ya just gotta dig it up...get it....dig it up!? :lol:
It's a joke son!!! Yer a chickenhawk son....a chickenhawk! Ya eat chickens! Boys plum Loco if ya ask me!! :blink: :)
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
07 Aug 2009 12:47 #312254 by KawiConvert
Replied by KawiConvert on topic jet setting for pods or stay with stock box?
I'm thinking of an airbox that surrounds the pods, best of both worlds!!!!
Ok, actually I'm thinking of making my own airbox as pods are expensive, stock airboxes won't fit my bike anymore and its something to do in the off-season. Any ideas? Also, I need to make it fit a 750 in a 650 frame. Also, any ideas for the proper airbox design? For cost I'm tempted to adapt some form of dirtbike type foam filter and oil it. Easy to clean, cheap to replace, just need to insure I have enough filter surface to pass enough air for the engine.
Get some 0.09" aluminum sheet, measure, cut, bend, weld seams, cutout intake boot holes, weld on a bung for the crank case breather.
Anyone done this before?
Ok, and pods or stock, if you have stock, put a K&N paper in the stock airbox, that'll flow a bit more, adjust your jetting and ride. I have pods because my stock airbox was toast, my tank mount makes a stock airbox impossible anyways, and pods were 32.00.
I've have some wind issues and jetting took forever to get to running reliably with decent power. So the moral is do what ever you want, its your bike and really, enjoying the ride is all that matters.
The rest of you can knock each other out, I'm going to get some paper and start sketching up some ideas.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
08 Aug 2009 19:58 #312522 by will61310
yeah, ive seen it done before on a zx-11, if youre decent at bending and welding anythings possible.
...1980 LTD 1000...
11 Sep 2009 17:20 #320802 by KZ1R1000
Replied by KZ1R1000 on topic jet setting for pods or stay with stock box?
pods rock!! Well, unless you ride in the rain. I do like the look of pods but water bad
