KZ Will stay running at idle
- jannin
03 Aug 2009 11:37 #311212
by jannin
KZ Will stay running at idle was created by jannin
I recently picked up a 1981 KZ250D2. It had been sitting for a year. I Drained the old fuel out of the card and put new gas in. I can get it running as long as I have the throttle on. As soon as I let off it dies. I plan on taking the card off of the bike and taking it apart and cleaning it. This is my first Kawasaki(had Suzuki GS before) Is there anything I need to look for in particular?
- Sandy
- Fly High,Tony
- Thank you received: 13
03 Aug 2009 11:42 #311214
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic KZ Will stay running at idle
You may have to adjust the idle setting on the carb.
1977 KZ1000 A-1
- jannin
03 Aug 2009 11:45 #311215
by jannin
Replied by jannin on topic KZ Will stay running at idle
Where do I find that? Would that fix the problem without having to pull the carb?
- Bullitt03737
03 Aug 2009 12:06 #311216
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic KZ Will stay running at idle
It will be a knob on the bottom of the carb rack, centered between all of em. That will adjust your idle speed up and down.
More than likely the carbs will need to be removed and cleaned out.
- Sandy
- Fly High,Tony
03 Aug 2009 12:28 #311218
by Sandy
1977 KZ1000 A-1
Single carb...should be pretty straight forward to clean it out.
1977 KZ1000 A-1
- OKC_Kent
- Thank you received: 20
03 Aug 2009 13:27 - 03 Aug 2009 13:54 #311223
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic KZ Will stay running at idle
Idle is set by the screw in red, right side of the carb. If you tear down the carb be very careful not to damage the rubber diaphragm. Do not spray cleaners on it or rip it. Big bucks for that part.
Oklahoma City, OK
Last edit: 03 Aug 2009 13:54 by OKC_Kent.
- jannin
03 Aug 2009 13:34 #311225
by jannin
It will only run at 2500+ rpm. I think it is a carb problem but I will check that screw
I believe 16014 is the one that might need adjusting
- OKC_Kent
03 Aug 2009 13:38 - 03 Aug 2009 13:57 #311226
by OKC_Kent
Oklahoma City, OK
Let me try a better picture, hopefully.
OK it seems the filters at work are messing with my attempts to post a pic.
Do you know that you can access your bikes part diagrams on the Kawasaki website, or other sites such as Bike Bandit? The pictures will be nicer than the one I posted.
Oklahoma City, OK
Last edit: 03 Aug 2009 13:57 by OKC_Kent.
- toadson
03 Aug 2009 18:38 #311305
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic KZ Will stay running at idle
My guess is your idle jet is plugged up, so no gas would be flowing at idle. When you give it some throttle, gas is coming out of the intermediate jet and letting it run. Just my guess.
- Sandy
- Fly High,Tony
03 Aug 2009 19:59 #311344
by Sandy
1977 KZ1000 A-1
1977 KZ1000 A-1
- jannin
04 Aug 2009 06:06 #311469
by jannin
I took the carb off last night and cleaned it out with some carb cleaner. I sprayed out all the jets and cleaned the floats. I noticed that there is a sping loaded flap on the choke plate that was hanging down. I fixed the spring on that and put it all back together. It runs much better now and It idles about 1500 rpm with only a few sputters. I am charging the battery now so my next project is checking the valves and tires!
Thanks for all your help
