Anyone with a similar situation?
- Royal1MC
- Is it just me, or is it just great to be on a KZ
03 Aug 2009 08:13 #311139
by Royal1MC
*1980 Z1-R (current))
*1978 KZ1000 LTD w/ Z1-R frnt end (sold)
*1977 KZ650 B1 (sold)
Los Angeles, CA
Anyone with a similar situation? was created by Royal1MC
I'm having a issue with my gas tank. I can ride locally with no problem, but on the highway after a few miles the bike spudders and pops. I check the gas line and no fuel was in the line to the carbs. I opened the gas lid and the fuel flowed into the carbs. Is this a petcock or gas lid issue?
Los Angeles, CA
- Johnj
03 Aug 2009 08:16 #311143
by Johnj
Veho vivo - Ago ut veho
Replied by Johnj on topic Anyone with a similar situation?
It's a tank vent problem for sure.
- bill_wilcox100
- Thank you received: 5
03 Aug 2009 08:41 #311153
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Anyone with a similar situation?
Like Johnj said.
The Gas Cap has two seemingly contradictory functions.
First is to seal the tank so that gas does not get on your paint job and the easily sourced and replaceable flat rubber seal does that.
Second is to vent the tank so that air can get in to replace the volume of the fuel being feed to your carbs.
I've never fixed a Gas Cap vent problem so others will have to tell you how they solved this problem. However, two solutions seem obvious. One is to change the Gas Cap which is a little extreme and the most expensive unless you happen to have a donor bike. The other is to disassemble the Gas Cap and clean out the rust/crud... but, as I said, I've never had to do this... not even sure if can be disassembled, for that matter.
Hope this helps.
Best of success.
Bill
Hope this helps.
Best of success.
Bill
Upgrades:
Montreal, Canada
- Thank you received: 2829
03 Aug 2009 10:16 #311168
by 650ed
Replied by 650ed on topic Anyone with a similar situation?
I can't speak for every flavor gascap, but the one on the KZ650C1 is very easy to disassemble and reassemble. Just be sure to note the position of the little parts inside. Ed
- Royal1MC
03 Aug 2009 11:40 #311213
by Royal1MC
Los Angeles, CA
Replied by Royal1MC on topic Anyone with a similar situation?
Thanks guys for your input.
Los Angeles, CA
